#1 |
HISTORY REPEATED 11/04/08
Tokico Blues + NF210s Installed
After starting on Thursday and taking my time I finished installing Tokico Blues and Tanabe NF210's on the Yaris. The backs for the most part were easy. I had to use the impact wrench to get the top nuts off of the shocks. The fronts were more difficult, I had to use some force to get the "brake assembly" into the shock so I could put the 2 19mm bolts in but, besides that it was straight foward.
So far I only driven on the backroads but, the car is much more stable and planted to ground a little bouncy beacause of the NF's but nonless a huge difference compared to stock. I also tried to shake the car from the outside I can barley get it to move and it doesn't sink anymore when I sit in the seat. Before with DF210's and After Shots with NF's and Tokico's. Last edited by bdc87; 11-24-2008 at 02:57 PM. |
JDM yO!
Drives: '09 3dr. 5-spd Join Date: Oct 2008
Looking good mate! Now for them to settle in for an even lower stance! =P
I'm thinking of following the same path (tokico + nf210).. |
#3 |
bronze looks good. needs darker tint!
#4 |
#5 |
Break'em off some.
Drives: 07 Yaris LB, 04 Cobra Join Date: Jan 2007
Nice work!
Get a TRD rear sway bar next and prepare to be amazed! |
#6 | |
Shut your fricken suck!!!
#7 |
Break'em off some.
I do what I can.
#8 |
#9 |
'07 to '12:2 wipers to 1?
Drives: '12 5-door LE & '14 5-door LE Join Date: Apr 2007
DON'T FORGET TO GET AN ALIGNMENT!
I say this as suspension components were removed and replaced with modified (read- different) parts |
#10 |
Drives: 2009 Yaris liftback Join Date: Nov 2008
looking sharp man!
#11 |
Waiting to get the alignment until the springs settle. The TRD sway is in my list of my next three mods, I'm looking at RH's Header, TRD Sway, and JDM tails but I'm undecided in the order.
#12 |
I used to have 1700 posts
y didnt u keep the df's?
#13 |
#14 |
Very nice, I also installed NF210s last week, the best upgrade I made to improve my cars ride.
. CLA 250, 4MATIC |
#15 |
i see. i intend to do rip out the back seat and anything that adds weight, replace my 18's for light weight 15's or 16's. would you say that i would be safe using these shocks with the DF's?
#16 |
★weeaboo★
Lookin' good!
I really need to get some blues for me. I'm rubbing over every bump or dip, and I tried doing a mountain run a week ago or so and got some nasty rubbing at every tight turn. I do not look forward to changing out the shocks.
#17 |
I don't drink anyway.
#18 |
JDM yO!
Do you have an images of it from the side view? It looks to be slightly higher in the rear end, because i thought the NF's were supposed to lower it 0.2" lower then the front (1.1/1.3)?
| Tokico HP (blues) Shock/Strut driving impressions. | largeorangefont | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 24 | 09-09-2010 12:03 AM |
| Tokico Information | nemesisz | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 3 | 09-25-2007 08:21 AM |
| Which options are dealer installed? | grampi | New YARIS Purchase Forum | 4 | 07-30-2007 01:23 AM |
| Tanabe NF210's installed...got a question though | Terrorize | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 32 | 09-29-2006 07:45 AM |
