Drives: 2007 Toyota Yaris Sedan Join Date: Dec 2008
Help: Need Info on Removing the Center Panel
![]() I bought my Yaris used and I don't like the color of the Panel. Red = yuck. I also need to get at the radio harness. I'm sure there is a thread for this already, I wasn't able to find it. Any help would be appreciated. Thanks. <3 |
Drives: stock yaris 2005 Join Date: Apr 2009
LoL
this thing must be changed!!!! ;p |
Drives: 2007 4 Door Yaris Join Date: Jan 2009
pull on stuff til it comes off?? I ripped about 20 panels off the yaris before I ever looked in a manual
Here's a DIY on painting the console: http://www.yarisworld.com/forums/showthread.php?t=4079 And here is the 2007 yaris factory repair manual http://www.etimago.com/yaris/repairmanual/ |
Yaris = <3
Drives: '08 Sedan - Flint Mica Join Date: Jan 2009
The little piece below the red comes off first. Pull on either side of it.
The two pieces on the right and the left side of the red come off next. Use both hands, one toward the top, one toward the bottom and pull out firmly. Then above the red, the part that is level to the ground and also surrounds the console gauges comes next. Pull toward yourself. Then the top piece of red is next. You'll need to unplug the 4-way flashers from behind before it lets go. And last, the bottom piece of red. You'll need a small flat head screw driver to remove the knobs from behind. The two red pieces will be the hardest to get off but all the parts just snap out and back in. Reverse the procedure to get everything back in. Good luck! |
| DIY: Replacing 2-Door Liftback Door Panel Fabric | redyaris | DIY / Maintenance / Service | 25 | 06-25-2024 01:24 AM |
| How do I remove "Instrument Panel Finish" | markitect | In Car Entertainment + Electronics (audio / video / alarm) | 3 | 11-26-2008 04:27 PM |
| AC Panel Question | slvryaris | DIY / Maintenance / Service | 1 | 09-04-2007 07:16 AM |
| Removing Door Panel | KSIbucky | DIY / Maintenance / Service | 7 | 10-04-2006 05:14 PM |
| Black Center Panel for Yaris Liftback | RoninMax | Cosmetic Modifications (Exterior/Interior) | 25 | 08-31-2006 05:53 AM |
