Old 05-29-2009, 03:54 PM   #1
Thirty-Nine
Small cars are a big deal
Thirty-Nine's Avatar
Tachometer Illumination
So, I've searched and found a few threads regarding aftermarket tachometer illumination. I've wired up my Autometer Autogage tach, and now need to illuminate it.
I saw that you can use an add-a-fuse in slot #23 as shown here (I have the mini add-a-fuse, but it's only rated to 10 amps):
http://www.yarisworld.com/forums/sho...r+illumination
... and I've heard of people tapping into the stereo dimmer wire.
Can anyone give me a definite answer as to how to illuminate this tach? Is one way better than another?
Old 05-29-2009, 04:28 PM   #2
Tamago
Start another Oil Thread!
Tamago's Avatar
Drives: ZZW30
hopefully one bulb won't pull more than 10 amps :D i say add-a-fuse
Originally Posted by xnamerxx
you nailed it sir.
Old 05-29-2009, 04:49 PM   #3
The output of the light control rheostat (connector D29) controls the radio illumination, AT shift lever illumination, and AC control illumination.
You can tap into the green wire in pin 2 for the negative side of the illumination circuit and any +12V source as your positive (such as the light blue wire in Pin 10). Pin 2 varies from 0 Volts (full brightness) to 12 Volts (fully dimmed). This will allow the tach to dim with the rest of the controls.
Old 05-29-2009, 05:38 PM   #4
Thirty-Nine
So, I did the add-a-fuse thing using fuse #9 and the tach illuminates ... but it stays on even if the car isn't on ... Can I just use any other 10am fuse spot? Can I use any open port with the add-a-fuse?
Old 05-29-2009, 05:59 PM   #5
Thirty-Nine
I put the add-a-fuse in slot #7 and it all works fine. Woo hoo. Now let's hope my wiring job holds up.
Tach Illumination wire Liu997 DIY / Maintenance / Service 6 05-29-2009 12:11 PM
Source code for Yaris Tachometer metalshark DIY / Maintenance / Service 27 04-06-2009 01:41 AM
LED Tachometer Units Sodium Duck Performance Modifications 5 02-28-2009 09:06 AM
FS - Brand New "TRD Styled" Tachometer (Red on Black) Ran Kizama Items for Sale by private party 9 05-09-2007 04:30 PM
HELP tachometer problems!!! SamDaYarisMan In Car Entertainment + Electronics (audio / video / alarm) 16 09-08-2006 03:26 AM
