Old 12-30-2006, 08:11 PM   #1
wushumasterku
Drives: 06 White LE HB 5spd
15" or 16"
guys, i need some advice again. what are the drawbacks of getting 16" rims as oppose to 15"? in terms of mileage and handling trade off... which would you get? (i want the racer look).
thanks!
p.s i'll probably be getting trd springs
wushumasterku is offline   Reply With Quote
Old 12-30-2006, 08:17 PM   #2
Black Yaris
der Zeck
Black Yaris's Avatar
Most every one who knows what they are doing around here that does Solo and scca races runs 15's on most smaller cars (mostly civics around here). The trick is get as wide as you can for stibility, yet have enough sidewall to flex to not loose traction on high G turns... my recommendation is a 15X7 to a 15X8 with a +30 to a +40 offset running a 225/50R15 tire.... That would be the Ideal set up.... and it is at a relitively low cost.
My set up (listed below) only ran me $450 and my car corners like it's her job, and I have not even lowered her yet
Old 12-31-2006, 01:42 PM   #3
Katana
Katana's Avatar
Drives: Yaris LB 1.3lt 06
Mmm, nice advice there.
I have the custom 15'' aluminium rims and I have installed 195/55-15 tires.
Old 01-02-2007, 01:50 PM   #4
St_G
Drives: Black 2007 Yaris Liftback 1.5
Are there any online wheel retailers that list the weights of the wheels? I'd like to stick with a 15", but would like to go a bit lighter than stock.
St_G is offline   Reply With Quote
Old 01-02-2007, 01:52 PM   #5
ChinoCharles
Drives: LB
http://www.yarisworld.com/forums/showthread.php?t=876
Support our vendors! Buy some Konig Heliums... they're as light as you're going to get for the price, and trust me... the price is good.
Old 01-02-2007, 07:56 PM   #6
YarisGuy
Drives: 2006 Yaris
Heliums FTW
YarisGuy is offline   Reply With Quote
Old 01-04-2007, 04:32 AM   #7
spkrman
Drives: 1
I fully intend on it before summer :)
Old 01-04-2007, 12:24 PM   #8
ChinoCharles
Drives: LB
As do I.
Old 01-04-2007, 04:55 PM   #9
Nutzoids
Nutzoids's Avatar
Drives: 07 Yaris Liftback
I found this... It ROCKS hardcore... hope you can use it!
Tire Size Calculator
Use the calculator to see what happens to your speedometer reading when you change the size of your tires and wheels. The graphic shows your stock tire selection in an outline overlaid on your new tire selection.
http://www.miata.net/garage/tirecalc.html
Nutzoids is offline   Reply With Quote
Old 01-02-2007, 09:00 PM   #10
wushumasterku
i will get those soon.. either 15 or 16
Old 01-03-2007, 11:29 PM   #11
graywolf_14
Drives: um not a yaris but hopefully
wow
Wow looking at the 225/50/15 at pepboys seemed like they had a smaller sidewall. I would probley go with a 16 with a 215/45/16 or something along that.
graywolf_14 is offline   Reply With Quote
Old 01-04-2007, 12:22 PM   #12
Tamago
Tamago's Avatar
Drives: UZJ100
www.goodwinracing.com has a few very good 15's
www.edgeracing.com also has some 15's. both sites list wheel weights...
Stock (optional) Toyota 15" alloy wheels boris13 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 9 12-30-2006 08:51 AM
205/50/15 tires on the S sedan 15" standard alloys??? CASTREX Wheels, Tires and Suspension Forum sponsored by The Tire Rack 4 11-16-2006 07:41 PM
ultra-light 14" or 15" wheels for Yaris 3dr leandro82 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 51 11-14-2006 02:07 AM
WTB: 15" steely and hub cap Wayside Items for Sale by private party 8 10-29-2006 08:21 PM
15" alloys weight? obylium Wheels, Tires and Suspension Forum sponsored by The Tire Rack 0 10-25-2006 12:05 AM
