Old 10-19-2006, 03:22 PM   #1
leandro82
Drives: S2000
ultra-light 14" or 15" wheels for Yaris 3dr
What's a good choice for a light but durable wheel at 14" or 15" to replace the stock 14" steelies on a base liftback?
I am not interested in anything bigger than 15" and 14" would prob. be better. I like to do solo and some other AutoX from time to time. TE37s were recommended but these are ~$300 each. Cannot find SSR-C in the small size. Any other choices?
Thanks
leandro82 is offline   Reply With Quote
Old 10-19-2006, 04:14 PM   #2
ItsMyDaily
The LittleBastard
ItsMyDaily's Avatar
I'll be getting the ssr competitions myelf. 8lbs for the 15"!!!! Tire rack only has 16" right now, but if your patient like I am being then you can get the 15" in due time.
If your looking for cheap rims that weigh nothing then try the rs watanabe's. They also weigh around 8lbs i believe for the 15" and aren't nearly as expensive as the te37's
Yaris Mods:
20% Tints
Ground wires
2007 Toyota Yaris Liftback - Current
2004 Honda S2000 - Sold
1986 Toyota Corolla SR5 - Sold
DIY: Groundwire Kit
ItsMyDaily is offline   Reply With Quote
Old 10-19-2006, 05:39 PM   #3
leandro82
Drives: S2000
Thanks, who sells the RS Watanabe's and how do they rate in durability?
SSR-C seems to be the best option right now. I know they make small wheels for Miatas and the like, will keep my eyes on Tire rack for them.
Old 10-19-2006, 06:48 PM   #4
ItsMyDaily
The LittleBastard
ItsMyDaily's Avatar
not sure where you can get them, but they have been around for a long time. You often see them on 86 corolla's, or 240sx's, datsuns, etc. Try searching to see who can supply these online. Actually I think there is a yarisworld member who has a set himself if I remember correctly. Sometimes you can find them on ebay for around $400
Yaris Mods:
20% Tints
Ground wires
DIY: Groundwire Kit
Old 10-20-2006, 02:09 AM   #5
jmew0ng
Drives: Scion FRS
make sure it's rs watanabe and not konig rewinds haha.
jmew0ng is offline   Reply With Quote
Old 10-20-2006, 10:40 AM   #6
ItsMyDaily
The LittleBastard
ItsMyDaily's Avatar
true. the konig rewinds look great, but they are a bit heavy.
Yaris Mods:
20% Tints
Ground wires
DIY: Groundwire Kit
Old 10-20-2006, 01:14 PM   #7
BulletProofAuto
Drives: 00 itr
i can source the rs watanabe's for you brand new, but you'll find that the pricing is really not much better then the volks.
best price on wheels right now are between the buddy clubs and the work emotion cr-kai.
http://www.yarisworld.com/forums/showthread.php?t=1818
http://www.yarisworld.com/forums/showthread.php?t=1189
if you want some crazy widths and offsets look at the work equips. the rays gram lights are cheaper then the volks also, and they're very light.
BulletProofAuto is offline   Reply With Quote
Old 10-20-2006, 06:18 PM   #8
leandro82
Drives: S2000
Thanks John - how do the gram lights compare to Volks, which I always hear great things about? These days it seems 14's just out of the question / only for track use. Call me crazy but I like the look of the small, tidy wheels on this car.
Looking at 185's or 195's with 50-60 series, that gives about 6.0-6.5 width let's say?
So far I've got:
Volk TE37s 14x6 to 15x6.5 $265 to $320
Volk CE28N 15x6.5 $300
Kodiak 14x6.5 about $300 and up but can get them cheap from a friend
SSR-C 14x6 $253, 15x6 $281
Gram Lights 57s 15x6.5 $200
Work Emotion CR Kai 15x7 $241
I don't know what kind of leeway I can handle in terms of offsets, will keep lookin into this.
Old 10-20-2006, 07:48 PM   #9
SAKU
SAKU's Avatar
Drives: White 3-Door Yaris
Send a message via Yahoo to SAKU
how about some work rims???
they look pretty good
somethin like the emotion cr kai???
Saku Ono
leo24@cornell.edu
SAKU is offline   Reply With Quote
Old 10-21-2006, 11:40 AM   #10
leandro82
Drives: S2000
How much do those weigh, do you know? The Emotion CR 15x7 in wheelweights is listed at 15lbs which is not that much lighter than the 14" steelies (about 18 lb).
Old 10-21-2006, 03:09 PM   #11
ItsMyDaily
The LittleBastard
ItsMyDaily's Avatar
you know if your just looking for track rims with a good price then maybe something like the rota attacks. 15x6.5 and they weigh 10lbs. Very cheap rims also. Probably can get all four for around 300-400.
Yaris Mods:
20% Tints
Ground wires
DIY: Groundwire Kit
Old 10-22-2006, 01:08 AM   #12
leandro82
Drives: S2000
Well frankly I would prefer the strength of forged wheels as this car will be a daily driver. I already have a Miata which will become the dedicated track machine.
Paying $250 a corner for wheels on a Yaris is kinda silly I will admit, but I don't mind so much for high quality rims. It is looking like SSR-C or Volks at this point. Thanks everyone for the replies.
Old 10-22-2006, 03:25 PM   #13
grimez
grimez's Avatar
Drives: 2007 Yaris
I am down to either the Rota Attacks or the Konig Heliums.
grimez is offline   Reply With Quote
Old 10-22-2006, 06:27 PM   #14
OK Yaris
Drives: 2007 Liftback
I've been running the Heliums with the 185/60/15 stock tires for a month now. I bought them from the e-bay seller on your link. We had a problem with some casting flash on the hub of one of the wheels. The seller replaced it with no problems.
I feel the handling improved just by replacing the wheels. The tire sidewall is more straight up and down now due to the wider rim width of the Helium vs. stock 15" steelie. I have photos in the garage area of Yarisworld.
for the seller and the wheels.
OK Yaris is offline   Reply With Quote
Old 10-22-2006, 06:41 PM   #15
ItsMyDaily
The LittleBastard
ItsMyDaily's Avatar
The heliums are 15x7 correct? no problems with using the stock tires on them at all?
Yaris Mods:
20% Tints
Ground wires
DIY: Groundwire Kit
Old 10-22-2006, 07:08 PM   #16
OK Yaris
Absolutely no problems. The Heliums are 15x6.5.
Old 10-22-2006, 09:30 PM   #17
grimez
grimez's Avatar
Drives: 2007 Yaris
I love the look of the Rota Attacks, but the heliums are cheaper, and lighter... im stuck in a tough decision.
Old 10-23-2006, 09:02 PM   #18
SimmZ
Drives: 2k3 Cavalier & 2k2 Echo
Choose any wheels you want, but please stay far away from the Konig Helium...
Ref.:
http://www.yarisworld.com/forums/showthread.php?t=2328
2003 Chevy Cavalier Ecotec - His car!
2002 Toyota Echo Sedan - Her car... FOR SALE!
SimmZ is offline   Reply With Quote
Brand of tires on Yaris' 15" alloy wheels paeko73 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 16 10-11-2006 10:48 PM
Brand of tires on Yaris' 15" alloy wheels paeko73 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 5 10-04-2006 06:26 PM
KONIG HELIUM Ultra LIght Weight wheels C2AUTOSPL Wheels, Tires and Suspension Forum sponsored by The Tire Rack 31 08-03-2006 06:00 AM
