![]() ![]() Drives: Yaris 09 T-spirit 1.33 Join Date: Jul 2009
cup holder removal
hi can someone help me and tell me how to remove the cup holder the one at the top near the steering wheel ?
i second this....damn spilt coffee stains!!
![]() ![]() ![]() ![]() Drives: '07 Yaris HB Join Date: Apr 2006
It's actually pretty tricky. You have to open it first, then squeeze the sides in. There is a little plastic piece that prevents it from falling out, and you have to kind of stick a flat head screwdriver in there to make it come out.
Oh and make sure you remove the screw from the bottom of the holder (visible only when the cup holder is open). I'll see if I can post pics up a little later on today. I took mine out and put them in the dishwasher.
#4 | |
#5 | |
![]() ![]() ![]() ![]() Drives: 2009 Meteorite Metallic LB MT Join Date: Oct 2008
![]() Sorry, couldn't resist putting that in.
![]() ![]() ![]() ![]() ![]() Drives: Polar White - 5 Door '09 LB Join Date: Aug 2006
Instead of removing it, why not just stop using it? What are you going to do with that space where it once was?
#7 | |
i want to know what it needs to be done so when i go and collect my car i see if the damaged the surrounding from where they took it off |
Sorry for no pics yesterday, I totally forgot. Will go out and grab some pics in a few.
Ok so here goes. Don't mind the coffee stains lol cups tend to spill a lot in these holders, they get all the vibration from the road.
1) Remove the screw. I don't know if this is absolutely necessary but I do it anyways. ![]() 2) Take a thin screwdriver and try and pry one side, while taking your other hand and squeezing both sides together. You have to pull quite hard to get the top portion to come out. So don't be shy here. ![]() 3) Once the top piece is out, take your small screwdriver and pry & pull the clips near the bottom. There is one clip on each side, but the clip on the left is the easiest to get off first. ![]()
thanks for all your help
| CUP HOLDER REMOVAL? | SweetRS | Cosmetic Modifications (Exterior/Interior) | 13 | 09-19-2016 08:43 AM |
| Install Oil Pressure, Voltage and Temperature Gauges with DIY Holder | bieniman | DIY / Maintenance / Service | 4 | 05-19-2009 11:40 PM |
| reusable water bottle in the bottle holder | 50MPGDream | General Yaris / Vitz Discussion | 24 | 01-28-2009 01:51 PM |
| A eye for a eye but a Ipod for a cup holder? | yrsdrgn | DIY / Maintenance / Service | 30 | 05-08-2007 02:51 AM |
