toyota
our DRL is running in pulse.............
been wanting to go hid but now i am running into cases where if i need to keep my drl and just run a relay will still cause issue with the hid due to a stupid drl pulse...need to run straight 12v current thru even on the relay. capacitor is an option ..but man what ever happen to plug and play..
#2 | |
plug and play HID's i just saved you time and money.
yup.. i've had this problem where the DRL pulsed my fog relay... a cap fixed the problem.
the relay takes almost no power anyways... a 100uf cap will do the trick. by the way.. i've already told you about the pulsed DRL... |
toyota
OK UPDATE..just got back from this place where they sell hid and hid alone.. their digital ballast automatically shuts off drl plug and play for dual bulb u still got low beam hid and hi beam halogen..but im surprise no relay needed ..and yes we did try it out although i forgot to check my fogs if that was affected.... now since i didnt have time today ,tomorrow were testing bi xenon with built in relay and see if that works..
what'd it run you?
toyota
if i go dual bulb hid/halogen...its $80
now hes letting me try the new kit bixenon built in relay on each harness that one is $120 but i think i get get it for a bill...well see tomorrow. |
Drives: yw calls me douche and racist. Join Date: Aug 2007
Dude, 80 for a dual isn't bad at all.
Sry, I thought you meant dual xenons.
toyota
hate the dual xenons you have to run 2 pair of ballast on them..
there are 5 types of H4
1. single beam low...you lose your high beams 2. low beam HID w/ high beam halogen 3. low beam halogen w/ high beam HID (rare combonation) 4. bixenon bulb w/ hid high/low beams - - has mechanical bulb that moves 5. bixenon bulb w/ hid high/low beams - - has 2 hid bulbs, requires 4 ballasts the most typical bixenon kit in my experience is #4 aka H4-3
toyota
Did option 4 but even with relay it's still flickering. Damn pulse drl
rice rocket
Drives: 05 Echo Join Date: Feb 2007
as mentioned already, you just need a capacitor to smooth the output going to the relay. This will not work for ballasts directly connected to the bulb sockets without using a substantially large capacitor (and with the discharge-recharge phases it puts the cap under some stresses that are not ideal for this application), so the capacitor fix will only work for a relay harness.
toyota
Got this fixed just disconnected the blue wire in the drl relay it worked flawlessly
#14 |
I got it at the plug.. and had it rewired to the pin that connects to the orange wire...
#15 |
toyota
i just unplug the blue wire and thats it..no rewiring needed..
| DRL in Yaris from..? | Falconia | Cosmetic Modifications (Exterior/Interior) | 36 | 12-22-2010 06:01 PM |
| DRL in Yaris from...? | Falconia | General Yaris / Vitz Discussion | 3 | 02-25-2010 02:22 AM |
| HID flickering problem - DRL fog - Problem solved. | IllusionX | Cosmetic Modifications (Exterior/Interior) | 9 | 10-01-2009 07:37 PM |
| DRL disalbled. | IllusionX | DIY / Maintenance / Service | 0 | 10-22-2008 04:16 PM |
| DIY:Day time running light Disabled with stock fog light remain function | summergxz | DIY / Maintenance / Service | 12 | 09-26-2007 11:42 AM |
