Old 02-10-2010, 05:48 PM   #1
Falconia
Drives: Yaris 1,3 -01 Linea Luna
DRL in Yaris from...?
Hi!
I have read that Yaris have DRL (Daytime running light)s which can cause problems with HID xenon systems. I have Yaris 1,3 VVT-i, 2001. My question is, from which product year Yaris does have DRL? Do I need to remove DRL module if I want to hid-lights?
Thank you!
Falconia is offline   Reply With Quote
Old 02-24-2010, 11:52 AM   #2
nlpnt
Drives: '08 HB MT 1F8
It differs from country to country: in the US (DRL allowed but not required) '06-09 hathcbacks with the "All-Weather Guard Option" package (shipped by default to the northern tier of states) have it; it was eliminated from the pack for MY 2010.
Some Canadians (DRL required) have re-wired the car to use the foglights or parking lights as DRL with HID headlights.
nlpnt is offline   Reply With Quote
Old 02-24-2010, 10:16 PM   #3
to know if you have DRL... start your car, and release the handbrake.. If the headlights turn on, then you have DRL.
on a 99-2004 yaris, the DRL module is located just under the dash trim, on the left if you are left hand drive. I believe it is on the right if you are right hand drive... it's a brown box.
on that particular model, if you unplug it, it will cause the handbrake light to not turn on anymore.
Old 02-25-2010, 01:22 AM   #4
Falconia
Contiunued here: http://www.yarisworld.com/forums/showthread.php?t=25761
If disable DRL and all lights stop working.
