Old 10-01-2009, 03:27 PM   #1
RacerFreakXXX
JDM Fred
Drives: 06 Mazda Miata
Send a message via AIM to RacerFreakXXX
Intake Question... :/
Yes I know another intake question. I can't decide between AFE, Fujita CAI, or Injen CAI. I'm planning on getting a blitz supercharger this upcomming summer/fall (2010) so I want to start building a good setup for the supercharger.
Are people really having issues with CAI sucking in water in the yaris?
RacerFreakXXX is offline   Reply With Quote
Old 10-01-2009, 03:43 PM   #2
posaunemeister
Drives: 2008 Yaris S LB - MM
It doesn't matter. Either of the three will do just fine and will give you the same kind of gain.
No. The filter on a CAI is usually located in front of the hard plastic tire shield, so water should not get into your filter at all, unless you drive through a 2' puddle of water.
posaunemeister is offline   Reply With Quote
Old 10-01-2009, 03:44 PM   #3
ebay short ram ftw!
Old 10-02-2009, 09:05 PM   #4
06silveryaris
Drives: 2006 yaris
ebay short ram ftw!
+1 I have the cai from ebay its been great fits and no cel or any high priced BS to deal with
06silveryaris is offline   Reply With Quote
Old 10-01-2009, 03:54 PM   #5
hatchbackkid82
Drives: .
AFE.... great intake i have it, more like a short ram with a heatshield, nice fit and finish, good quality piece, plus you don't have to worry about sucking up water
Old 10-01-2009, 04:00 PM   #6
ROCKLAND TOYOTA
TRIM HUNTER
ROCKLAND TOYOTA's Avatar
TRD cold air comes with water bypass valve....
Old 10-01-2009, 04:14 PM   #7
...which I believe is recommeded to be removed if running a S/C.
Old 10-01-2009, 04:59 PM   #8
ROCKLAND TOYOTA
TRIM HUNTER
key word is recommended.....
Old 10-01-2009, 04:16 PM   #9
kurokoma-kun
Drives: 2007 Yaris HB
Read my mind Wee
The TRD's not recommended for use with s/c, there's a risk of some piece of that bypass valve being sucked into the blower... Noogie had to remove his trd cai, maybe Camell also? The one-piece designs dont present that problem.
I've heard the subject of hydrolock with a cai come up here before but never read any actual experiences.
my yaris, kurokoma-kun
Old 10-03-2009, 01:13 PM   #10
ozmdd
Reluctantly Crouched...
ozmdd's Avatar
Drives: 2008 Yaris HB M/T
Originally Posted by kurokoma-kun View Post
Read my mind Wee
I didn't like the condition of the by-pass fitting on the used TRD I got, so I just swapped-in a plain coupler. Works great, no problems, and you can adjust the fit a little more by cutting the coupler to the length you want.
I haven't compared it to any others, but I'm really pleased with the performance of my TRD CAI (using a weapon R dry filter)
I can tell you that I am running 2-3 degrees above ambient, vs. 20-30 degrees above ambient with the stock airbox.
Does anyone from a colder climate have any thoughts about the CAI in cold weather? How cold is "too cold" for the engine to run efficiently?
Old 10-03-2009, 01:19 PM   #11
posaunemeister
From my experience while living in Missouri, a state that gets both extremes of temperatures, CAI's work best when the temperature is low AND the humidity is low.
Old 10-01-2009, 05:28 PM   #12
RacerFreakXXX
JDM Fred
like I said I have 3 that I like for price and performance. My whole thing is, what intake comes in contact with more cold air flow/ more air flow.
Old 10-01-2009, 05:54 PM   #13
posaunemeister
My custom modified airbox/snorkle/foglight cover, with K&N drop-in filter brings in more cold air than all three of these, guaranteed.
But anyway, definitely not the AFE since it's basically a short RAM with a heatshield.
Old 10-01-2009, 06:36 PM   #14
RacerFreakXXX
JDM Fred
That's what I was thinking... I was also mainly concerned about water getting into a cai... but I really doubt that now. I am also considering a blitz lm intake, it's about $150-$200
Old 10-01-2009, 09:51 PM   #15
severous01
i'll tell you how i picked mine....and you should do the same.
find a good cheap used one with all the parts included.
the filters themselves are cheap if it's ruined, and the plastic doesnt go bad....and most bolts, threads, sleeves, mounts, or whatever else is involved can be easily repaired or replaced.
why pay 350 bux for a brand spankin new K&N when you can get one used for under a hundred....and most likely have absolutely no problems with it.
Old 10-01-2009, 11:55 PM   #16
posaunemeister
Exactly. That's wisdom + common sense speaking to you right there. :)
Shameless plug: http://www.yarisworld.com/forums/showthread.php?t=22547
Old 10-02-2009, 01:12 PM   #17
Are you disagreeing, and that you think it's ok to use the TRD CAI with the supercharger? A more clear answer, please.
Old 10-02-2009, 01:43 PM   #18
Brian
Brian's Avatar
I've had too many problems with TRD CAI. Its coming off as soon as I can afford something better. I'd go with the Injen.
Intake question Slick Performance Modifications 4 09-10-2009 10:29 PM
Air Intake Question ruimond Performance Modifications 17 11-29-2008 06:07 AM
Intake question cookfreeordie Performance Modifications 3 11-03-2008 10:45 PM
intake question and suggestions Adriaan Performance Modifications 2 01-31-2007 04:54 PM
