![]() ![]() ![]() ![]() Drives: Vitz RS Turbo Join Date: Nov 2008
1NZFE VS 4EFTE
During my project run I had many ppl around discussing about my engine, the 1NZ. Many, if not all say when comparing a modified 4EFTE with a modified 1NZFE, the 4EFTE perform much better. Also they say that the 4EFTE is more cheaper to build since many of the stock internals withstand heavy power beyond 250Bhp or even more. Well I could easily got into the route of the 4EFTE with minor modifications in the engine bay but all is done now.
I know many ppl have experience with different engines and maybe there are some could give me better advantages on the 1NZFE vs 4EFTE so that when facing these ppl I can give them some good feedback instead.. .
Who said Yaris was slow?
Well, they are probably right...
Couple of things... The 4EFTE is a much older motor than the 1NZ however this power plant was designed for forced induction. It is a stronger overall engine... with an iron block that can stand more power than the 1NZ in it's stock form. You can take the 4EFTE from it's stock 130 hp to to a little over 200hp with no modifications to the internals. This engine can handle some serious boost on a stock bottom end. You can not do that with the 1nz How ever when you are shooting for 300 hp even the 4efte will need to be re inforced (pistons, rods) At this power level I guess the 1NZ been a modern engine has better flowing capabilities. The other advantage of the 4EFTE that ca not be denied... is that has been around for a lot of years and is has much more aftermarket support than the 1NZ. Threfore probably the parts are cheaper and esaier to find. A lot of people has messed around with the engine so it's limits are known unlike the 1NZ that has only a few turbo'd examples around the world... |
The only things I didn't change were the internal springs and maybe going to bigger valves. How much bhp/boost do you think the 1NZ can hold of course with the internals I have?
#4 | |
Just from the top of my head I would say... I've we have see a few yaris boosting 7-8 psi on a stock motor with no problem... I think that with forged internals and a really good tune you could probably double that 14-16psi With race gas or meth injection perhaps a little more (18psi) But there are many factors here... not just the strenght of the internals. The abilities of your tuner will play a big role there... |
#5 | |
![]() Drives: Yaris ts 1.5 Join Date: Sep 2009
if you sleeve the 1nz fe ..... it will make greater horsepower than any 4e fte can make... so i prefer the 1nz fe!
| Just wanted to share this: turbo 1NZFE | as400g33k | Performance Modifications | 34 | 04-26-2013 11:39 AM |
| 1NZFE K1 by Carrillo Rod interest list | xBoosted | Forced Induction Forum | 20 | 01-20-2009 03:51 PM |
| 1NZFE Oil Cooler | Parmas | Forced Induction Forum | 23 | 11-24-2008 10:13 AM |
| Compiled 1NZFE Used Oil Analysis | craigq | DIY / Maintenance / Service | 7 | 09-10-2007 05:27 PM |
