Old 11-18-2008, 02:01 PM   #1
Parmas
Parmas's Avatar
Drives: Vitz RS Turbo
1NZFE Oil Cooler
Hi guys I am interested to include an oil cooler in the setup that had turboecho2005. What do you suggest in regards worth and efficiency with a 250HP engine?
Old 11-18-2008, 02:44 PM   #2
CASTREX
Who said Yaris was slow?
CASTREX's Avatar
Drives: Yaris T-Sport 2008
You definitely want an oil cooler with that kind of power... for peace of mind.
Is not a must, but is always recommended to have an oil cooler on a turbo set up. It will be a MUST if you are planning to do any track time on the car.
Old 11-18-2008, 05:36 PM   #3
turboecho2005
turboecho2005's Avatar
Drives: 2005 Toyota Echo
I'd recommend an oil cooler also. Although not needed it will help if you plan on any long periods of high reving...
Parmas... hows the project coming along?
Project Slowtop - Twin Engine 4AGE Blacktop Vitz - Twin Turbo - 503hp
1987 Nissan Maxima - 40,000 original miles - Slammed
1991 Isuzu Impulse RS AWD Turbo - approx 250hp - Winter Beater
1989 Isuzu Imark RS - Mint Condition - 0 rust - 100% factory :) - Summer Cruiser - 100% restored
1986 VW Jetta Wolfsburg - 120,000km - Mint condition. TDI swap in progress
turboecho2005 is offline   Reply With Quote
Old 11-18-2008, 06:29 PM   #4
Tamago
Tamago's Avatar
Drives: UZJ100
im using a b&m supercooler.. love it, oil temps are happy
Old 11-18-2008, 07:06 PM   #5
Nexus1155
Bathroom + Laptop = <3
Drives: Audi
you can piece your own together at summitracing for cheap money
Old 11-18-2008, 07:13 PM   #6
Tamago
Tamago's Avatar
Drives: UZJ100
that's what i did. i have about $40 in mine including the thermostat sandwich adaptor
Old 11-18-2008, 09:19 PM   #7
+1
www.summitracing.com FTW
Old 11-19-2008, 06:02 AM   #8
Parmas
Parmas's Avatar
I found a complete kit for the 1NZFE, http://www.automotiveconcepts.net/st...316311176.html
What do you think about this, worth the money?
*Project is taking longer than expected will update when I have relevant info.
Old 11-19-2008, 07:09 AM   #9
Tamago
Tamago's Avatar
Drives: UZJ100
piece it together yourself, it'll be cheaper.. and you don't need a cooler that huge ;)
Old 11-19-2008, 07:01 PM   #10
revoturbo
revoturbo's Avatar
Drives: yaris
Oil cooler works great for daily use too
multimakmurperformance.com
revoturbo is offline   Reply With Quote
Old 11-21-2008, 08:13 AM   #11
Parmas
Parmas's Avatar
What dimensions do you recommend?
Old 11-21-2008, 10:37 AM   #12
Tamago
Tamago's Avatar
Drives: UZJ100
http://store.summitracing.com/partde...5&autoview=sku
that will work fine
Old 11-21-2008, 11:42 AM   #13
Nexus1155
Drives: Audi
The one Tamago picked should be perfect...
Old 11-21-2008, 01:10 PM   #14
mount it behind the right air dam in the lower bumper
Old 11-21-2008, 01:12 PM   #15
Black Yaris
der Zeck
Black Yaris's Avatar
Hell you can pick up an oil cooler from Autozone for $25 or so
Old 11-21-2008, 05:05 PM   #16
I would buy that B & M for $49.95 over some cheap-o brand any day, especially when my engine's life blood depends on it not failing.
Old 11-22-2008, 01:45 PM   #17
Parmas
Parmas's Avatar
Thanks I am interested in your suggestion ... do you have any images to refer on?
Old 11-23-2008, 09:27 AM   #18
Tamago
Tamago's Avatar
Drives: UZJ100
i'm not sure if you have the same radiator brace as the xA but it's perfect for mounting a cooler:
DIY: CHANGE MANUAL TRANNY OIL ttufrosty DIY / Maintenance / Service 157 09-07-2018 01:43 PM
Updated: Compiled 1NZFE Used Oil Analysis craigq DIY / Maintenance / Service 4 11-26-2008 01:39 AM
Compiled 1NZFE Used Oil Analysis craigq DIY / Maintenance / Service 7 09-10-2007 04:27 PM
oil and oil filter question.. marcus DIY / Maintenance / Service 27 07-11-2007 03:25 PM
