Old 12-17-2009, 03:26 AM   #1
HDS
Drives: 07 Yaris, Saab 900 Turbo
Yikes, thats an expensive block heater
So temps are hitting -20C in Finland, starting is a bit of a hassle in the mornings without a block heater. So I had my car taken to the shop and I was told the heater would be 90 euros + 59 euros for the wiring harness. But then I was phoned by the shop and they said my car has A/C and that means the part won't fit (it bolts onto the engine as I understand).
So instead I must get one that splices into a coolant hose and it's a whopping 215 euros, anyone here know the part they are talking about? Is it really that bloody expensive?
HDS is offline   Reply With Quote
Old 12-17-2009, 06:23 AM   #2
WolfWings
WolfWings's Avatar
Um... the block heater for the Yaris (at least for the non-diesel engines) snaps into a pre-existing hole in the side of the engine block just above where the transmission bolts to the engine block. There's no wiring harness, it's a single kit that's about $45US for the whole thing, and includes the wiring in question.
I could see an hour's labor at the dealership at rather high rates for one installed, especially on a manual-transmission vehicle since part of the cable-guides need to be unbolted to access the hole, but it shouldn't end up more than about 100 euros total price for the whole thing for the actual Toyota version.
Old 12-17-2009, 07:30 AM   #3
HDS
The part you mention that snaps in, that was kind of type I thought I needed, but this one comes in two parts for some reason, 90 euros for the heater and 59 for the wiring harness (probably a bad translation, but the cables that come with it), I picked the parts up myself from the shops supplier to save on the shipping costs. It was supposed to snap in. But they called and said since I got an A/C that it will not fit, the A/C pump is in the way.
I have a diesel engine if that matters any.
Block heater R2D2 DIY / Maintenance / Service 80 04-24-2025 04:08 AM
engine block heater linny DIY / Maintenance / Service 6 01-19-2012 11:22 AM
My $7 Interior Upgrade - Center Heater Vents Meteorite_Marty Cosmetic Modifications (Exterior/Interior) 54 05-18-2009 08:51 AM
Rostra seat heater and lumbar support sesmith In Car Entertainment + Electronics (audio / video / alarm) 1 01-03-2009 08:51 AM
Where to find block heater cable that was factory installed? D6U4 General Yaris / Vitz Discussion 5 12-16-2008 07:04 AM
