Old 12-15-2008, 08:29 PM   #1
D6U4
Drives: 08 Yaris Sedan (E.C. Package)
Exclamation Where to find block heater cable that was factory installed?
Not sure where to find the block heater cable in my 2008 Toyota Yaris Sedan
D6U4 is offline   Reply With Quote
Old 12-15-2008, 08:39 PM   #2
D6U4
No not quite yet only had a quick peek.. It's dark outside
Old 12-15-2008, 08:44 PM   #3
D6U4
K thanks!
Old 12-15-2008, 08:49 PM   #4
Doc Zaius
Lurker supreme!
Doc Zaius's Avatar
Drives: old and boosted!
Mine came out between the hood and the bumper just next to the headlight. If you take a look around behind the air intake in front of the battery, you're likely to find it.
I've been thinking about moving my plug to the lower grille, but concerned about getting a lot of spray/salt/snow on it... I'm sure the plug cover will get knocked off. Is that where everybody else has their's?
2006 Red Blitzed RS 5-door
Old 12-15-2008, 09:02 PM   #5
they put mine in the lower grill....but i bought my car in august! lol
i took it out of the lower grill because you gotta stretch the mullions to get the plug thru there.
now i keep it up by the hood prop...and when i use it i just pull it out between the hood and bumper by the headlight....or up at the top of the hood by the wipers...
Old 12-16-2008, 07:04 AM   #6
MUSKOKA800
MUSKOKA800's Avatar
Block heater is likely a dealer installed option, not from the factory. If you cannot locate it check with your dealer. Perhaps they neglected to add it before delivery.
