http://www.lifeline-mts.
Drives: yaris Join Date: Oct 2009
dash board rattles
just his morning this "rattles" are coming from the dashboard
somebody had this before |
most likely your display . Fixed ours with sticky back felt . Will need to remove pieces located on both sides of climate control knobs and then the plastic part of upper dash that meets the display . There are a few screws that hold display unit in place . Then put sticky back felt on tabs that touch dash . Found it easier to sit on opposite seat to remove the pieces on side of climate control knobs by pulling out towards you ( pull left panel gently towards you when sitting in passenger seat , right when seated in driver seat ) . Be careful not to break off the tabs . Rattles are annoying . Seem to be the worst on the coldest days ( plastics constrict and are stiffer ) and warmest days ( expands touching other parts and weaker from strong sun ) . GOOD LUCK
#3 | |
do you have a picture DIY for this thanks |
my bad, its not the dash board , its the aftermarket rear view mirror
i put-in that's making the rattles
Roadrunner Jr.
It could be any of those plus other things. I speak from experience. Look to either side of the dash near the doors as well. I have a sound deadening primer in the ICE section of this forum if you want to see a little bit into the car.
I'll be tearing the dash down in April/May when I get back home from Iraq here. I've got some things to do.
“To argue with a person who has renounced the use of reason is like administering medicine to the dead.” ― Thomas Paine |
#6 | |
thanks bro... |
![]() ![]() ![]() Drives: Black Vitz Liftback Join Date: Dec 2008
Thanks for the tip, I need to do this despite having the TSB done which was a foam pad placed under the display-still getting a cold morning rattle.
| Toyota Silver Dash Kit | Meteorite_Marty | Cosmetic Modifications (Exterior/Interior) | 72 | 04-13-2012 01:42 AM |
| Trade upgraded radio and dash for base radio and dash??? | Yarisguy13 | Items for Sale by private party | 4 | 09-17-2007 06:32 PM |
| Brighter Dash lights, there is a switch??? | mgthompson | General Yaris / Vitz Discussion | 14 | 04-04-2007 08:51 AM |
| dash problems...help needed | foggy08 | DIY / Maintenance / Service | 1 | 01-25-2007 08:04 PM |
