![]() ![]() ![]() Drives: 09 Yaris 3 Dr White LB Join Date: Mar 2009
Taller Gears
IMO one of the best cars ever sold was the old civic VX, it did an honest 50 mpg.
It had really tall gears. I am planning on adding a LSD to my Yaris to help in the snow and was wondering if it is possible to buy a taller final drive ratio for the manual tranny ? |
#2 | ||
Start another Oil Thread!
PM MORGAN about the issues she had trying to swap transmissions. 1. mounts are different 2. shift linkage is different etc etc also keep in mind, the yaris uses an 8 bolt ring gear, and echo is 6bolt ring gear so you'd need to buy an echo LSD if you're gonna use it on echo final gears. yaris final drive: 3.72:1 echo final drive 3.53:1
you nailed it sir.
#3 | |
![]() Drives: 2007 Yaris HB 5-spd Join Date: Dec 2009
I also monkey with 1st gen Metros (XFis) and the taller final drive in the XFi is probably the #1 reason they get far better MPG's than the base model. If the echo could be a trans/final drive donor I would be interested in doing it. Has anyone had any experience with this since this thread was hot? Thanks, Brenton
I can see for Miles and Miles... |
I was wondering this too...but in my Pontiac G6 GT. I want to go the other way, increase RPM...not lower it lol.
Just to throw in an idea, the guys at www.richmondgear.com may be able to help, if not at least point you in the right direction. From the articles I've read, I think the Yaris should have a six speed, with sixth acting as a second overdrive. The automatic saps power but mileage stays in line with the manual as it turns lower rpms on the highway. |
![]() ![]() ![]() ![]() ![]() ![]() Drives: '08 Bayou Blue LB AT Join Date: Oct 2008
The AT Yaris could use another gear before overdrive. It still revs too high a highway speeds IMO.
aFe Intake | Blitz Supercharger | Megan Header | TRD Exhaust | NST Pulley Set TRD Shocks/Struts | Tanabe NF210 Springs | TRD Sway Bar | Motegi TRAKLITE wheels | Kuhmo Ecsta XS R1 Concepts slotted rotors | Carbotech 1521 brake pads | stainless steel brake lines | Seibon vented carbon fiber hood |
![]() ![]() ![]() ![]() ![]() Drives: . Join Date: Feb 2007
#7 | ||
![]() ![]() ![]() ![]() ![]() ![]() Drives: 07 Yaris 3dr LB (Bayou Blue) Join Date: Oct 2008
-Jen <3 ![]() Quote:
That ship has sailed.
Learn to Relax
Drives: 2007, Meteorite, LB Join Date: Dec 2008
I think the AT ratio is fine, especially for California freeway driving. Doing 80 all the time on the freeway, it's nice to still have power. A taller ratio will make the Yaris sluggish for California freeways.
Well im sure the small compact lightweight design was designed and geared more towards city driving. Like for people who live in San Franciso. Thus the gear ratio.
Half a Bubble Off Plumb
In the hills around here it downshifts a lot at Interstate speeds as is.
okay, but I'm not talking about AT (thank goodness. Hate them) having a taller final drive with the manual would improve MPG's on long trips (all I really do) and it's my opinion that there's plenty of lower gears to make up for the taller legs (like 4 of them)
Brenton
![]() ![]() Drives: S sedan Join Date: May 2009
get taller tires...
#14 |
So i take it know one here knows a damn thing about this topic?
#15 | |
+1 to YarisSedan's comment ^
meanwhile... There are alternate gearsets available from TRD in Japan, but they are shorter (for racing), not taller. I don't think you're going to find a taller final drive. You could have a custom one made.
#16 | |
#17 | |
![]() ![]() ![]() ![]() ![]() Drives: 07 Yaris S Sedan 5-Speed Join Date: Oct 2008
He's correctly suggesting that using taller tires (larger diameter) will create less tire revolutions to go a certain speed than the standard size. Hence, less engine RPM needed to maintain speed. ![]() That said, it won't make as much difference as a taller final gear of course. |
#18 |
Of course the main reason why Toyota didn't put a 6th gear in is economics. It obviously costs more. And a taller 5th gear creates weak torque performance on the highway. So that's not the answer.
Most automakers are starting to put in 6 speed auto's in cars as a way to boost MPG but only in the middle and upper class cars. Econoboxes will be last to get them. But when they do, it will do wonders for highway MPG. Yaris would certainly be EPA estimated over 42 and 45-50mpg could probably be achieved. Last edited by Kal-El; 12-27-2009 at 03:33 PM. |
| Optimal RPM for shifting Gears ? | JapRulezz | Performance Modifications | 8 | 03-07-2009 05:16 AM |
| gears of war 2 | ROCKLAND TOYOTA | Off-topic / Other Cars / Everything else Discussions | 25 | 02-16-2009 11:33 PM |
| Transmission versus Gears | caveatipse | General Yaris / Vitz Discussion | 3 | 09-23-2007 04:50 PM |
| Engine Run-on changing 1st/2nd Gears | Ferret_san | General Yaris / Vitz Discussion | 4 | 09-06-2007 01:21 AM |
| Gears | bulldogs2k | Performance Modifications | 17 | 07-26-2006 09:16 PM |
