Old 12-18-2009, 12:15 AM   #1
Hershey
Question 1st bar loss for 5 door hatchback ...
we've noticed there are less miles when losing the 1st bar with the '09 5 door auto than the '08 sedan with automatic . Has anyone else noticed this ? Wonder if the gas tank of the hatchback is positioned different than that of the sedan . The 5 door doesn't seem to glide or have as good rolling resistance as the sedan . Encounter this when coasting to a stop or when gliding done a hill . Feels like something is holding the 5 door back . Reason .
Old 12-18-2009, 03:27 AM   #2
yaris-me
Learn to Relax
Drives: 2007, Meteorite, LB
You should record your gas fill up and mileage to see what kind of mileage you're actually getting. I'm sure the shape of the tank has something to do with what's happening, but your true gas mileage will tell you if something is really different.
Old 12-18-2009, 05:10 AM   #3
Yaris Hilton
Half a Bubble Off Plumb
Yaris Hilton's Avatar
Drives: 2009 Yaris Sedan
Smile
If it doesn't coast as well, check tire pressure and wheel alignment.
Old 12-18-2009, 11:50 AM   #4
Hershey
check pressure every week or two . Keep tires for both at about 35 p.s.i.. Would hope alignment be good since '09 5 door has less than 9,000 miles .
Old 12-18-2009, 11:48 AM   #5
Hershey
keep mileage for both .
Old 12-18-2009, 12:53 PM   #6
DevilGirl
Drives: 09 3dr LB MT
So overall, are they about the same MPG with each fill up?
Or is there a difference too?
Is it the same person driving both vehicles on a consistent basis?
Various factors involved. Driving style being a large one.
Old 01-05-2010, 02:10 PM   #7
Sidicas
Drives: 2010 Toyota Yaris Hatchback
My guess: Having a gas efficient car in the car dealership lot is harder to emphasize when it doesn't always have a full tank. So by making the first bar indicate a larger quantity of fuel than the other bars, it's easier for the dealership to keep the car driving around all day long on test drives while appearing to always have a full tank..
Just my guess.
Sidicas is offline   Reply With Quote
Old 01-05-2010, 03:24 PM   #8
127.0.0.1
Drives: '10 Yaris5drHB+99 4runner LTD
Just my guess.
no that is not how it works.
the float is pressed up to the top on a full tank. it is drowned in gas. and more gas needs to be
consumed before the float falls. once the float drops, then the gauge is very accurate. 1/2 tank on gauge = 1/2 tank really left.
the first bar takes a long time to drop because of 'float drowning'
in-tank radar or sonic detectors (used to check fluid levels in all sorts of industrial tanks, a lot
like bumper backup detectors)
would be more extremely accurate but pricey. hence, the old school float is still used today.
in-tank radar is used in some breweries and refineries to detect levels. also used in
fuel delivery systems. I modified a collision detector to tell me how much water I have in the
boiler on my 4-4-0
127.0.0.1 is offline   Reply With Quote
Old 01-06-2010, 12:08 AM   #9
Hershey
we've also noticed that the overdrive for the '09 automatic doesn't come on as quick as the '08 auto sedan after climbing a hill in the 3rd gear . Wonder if the computer for tranny is not calibrated properly in the '09 .
Old 01-14-2010, 03:02 PM   #10
supmet
Drives: 2007 4 Door Yaris
Its not a calibration issue, its a learning ECU issue. You usually don't gas it hard in 3rd going up hills, so your 08 already knows just to go down to O/D. The 09 still needs some time to learn your driving habits.
Old 01-14-2010, 04:58 PM   #11
jambo101
jambo101's Avatar
Drives: yaris 08 sedan
Could be just the time of year as cold weather and winter gas formulations and short runs and winter tires arent the best time to expect your best fuel economy..In my 08 sedan in summer highway driving i can get 130kms before the first bar disappears,in winter in city traffic its usually gone around 90kms..
Old 01-14-2010, 02:47 PM   #12
MUSKOKA800
MUSKOKA800's Avatar
It's been said that the sedan is slightly more aerodynamically efficient than the Hatch. But like HILTON said, check for mechanical differences.
DIY - rear sway bar [pics] cali yaris DIY / Maintenance / Service 199 07-28-2022 05:25 AM
DIY: Strut Tower Brace Bar redyaris DIY / Maintenance / Service 18 03-16-2014 06:52 PM
Ultra Racing 23mm Rear Stabilizer Bar Loren Performance Modifications 62 05-18-2009 07:20 PM
C-Pillar Bar Installation Guide AlainMikli Wheels, Tires and Suspension Forum sponsored by The Tire Rack 13 05-08-2009 09:29 AM
solid torsion bar bushings... the best rear anti roll upgrade turboyaris Wheels, Tires and Suspension Forum sponsored by The Tire Rack 28 12-05-2008 11:37 PM
