Old 02-21-2010, 09:02 AM   #1
MCALLEN10749
Drives: toyota yaris 2005
TIMING TOOL FOR YARIS
MY YARIS IS OFF CYCLINDER 1&2 AFTER NEW VALVES INSTALLED,DO I NEED A SPECIAL TOOL FOR TIMING CHAIN. CAN THE CHAIN STRETCH
MCALLEN10749 is offline   Reply With Quote
Old 02-21-2010, 09:36 AM   #2
DerFlosser
DerFlosser's Avatar
Drives: Yaris
I haven't been inside this motor but did you mark the position of the chain and sprocket(S) when you the cams. I am assuming that there are timing marks on bearing caps to the front and the cam base. Obviously, everything should line up at TDC so then it comes down to possibly having slack in the chain if not marked prior to removal.
DerFlosser is offline   Reply With Quote
yaris timing belt phenoyz General Yaris / Vitz Discussion 16 02-24-2015 02:05 AM
CAM TIMING jt258 Performance Modifications 21 11-12-2009 01:50 PM
australian vs american models: timing chain hoobyjuice DIY / Maintenance / Service 3 06-16-2009 10:25 AM
OBD2 scan tool to save fuel worth it? ezhacker1 Fuel Economy Forum 11 05-08-2009 10:04 AM
Timing chain, sprockets, & cam position sensor problems? PetersRedYaris DIY / Maintenance / Service 8 01-04-2007 12:50 PM
