Go Back   Toyota Yaris Forums - Ultimate Yaris Enthusiast Site > Second Generation Toyota Yaris Main Rooms > Regional Forums > Australia
Old 04-05-2010, 09:36 AM   #1
hazzy
Drives: Yaris YR
Help on YR Wheel Size
I have a 09 Yaris YR, and im looking to replace the OEMs with 17"s, hopefully.
However i've heard that it can only go 2 sizes up.
Since the YR model is fitted with 14"s, im wondering if they are able to fit.
Thanks in advance
hazzy is offline   Reply With Quote
Old 04-06-2010, 12:28 AM   #2
spookz
JDM yO!
Drives: '09 3dr. 5-spd
The rims itself will fit, it's just that some insurance companies have a policy of only covering you for 2 sizes up. Having said that, most people don't seem to care.
Old 04-06-2010, 01:21 AM   #3
hazzy
Drives: Yaris YR
Hmm thanks for the clarification,
Also im given to understand that 16's are the perfect size for both comfort and style than 17s.
Is this true or is it what some people prefer?
Thanks again
Old 04-06-2010, 02:28 AM   #4
spookz
JDM yO!
I would say that 16's are more comfortable compared to the 17's as you'd have more rubber around the rim to act as cushioning.
However, as for style, this is purely what people prefer. I personally prefer more rubber (smaller rims) for that track-oriented look, while others prefer less rubber (bigger rims) for that sleek look.
Hope that helps! Btw, welcome to the forums and post up pics of your ride! :)
Old 04-06-2010, 05:03 AM   #5
Kiz
Kiz's Avatar
Drives: '06 Yaris Hatch and TT 300ZX
My YR came with 15" factory alloys and a tyre placard to suit, so if you could get a hold of a placard for 15" rims you could technically put 17s on legally.
The main thing to check is offset when purchasing wheels. Always do a test fit too :)
'06 LB 2NZ-FE w/ NST crank pulley "No RWKW" | '89 2+2 VG30DETT Z32 300ZX "Lots RWKW" ;)
Kiz is offline   Reply With Quote
Old 04-06-2010, 05:24 AM   #6
AND189
Drives: 2
hazzy
i 2nd spookz if your looking fro bling then go for it if you are looking for performance then you may have to look hard, if you are going to throw it around then you are going to burn rubbers and for a good/ better set of tyres for lets say 15"because that is what oi have, you can get a set of 195/50/R15s Bridgestone potenza adrenalins for $120 each and i must say they are i real nice tyre if you were to get 17 you are looking at $180 -$230 for good tyres on top of that the extra weight in big wheels can have a big effect on speed =) be sure to inform your insurance man when making changed that effect performance, a yaris dose not need big wheels to look good ;)
AND189 is offline   Reply With Quote
Old 04-06-2010, 06:38 AM   #7
hazzy
Drives: Yaris YR
@AND189
Probably more bling than anything, however i have taken into consideration the weight issues of 17's and still not sure as to get 16s or lightweight 17's which will be more expensive. Since its a 1.3L YR going uphill will be a pain with some heavy 17's.
Thanks for all the input guys
@Spookz Unfortunately its stock, havent done any modifications what so ever, therefore there is nothing to see
Old 04-06-2010, 06:42 AM   #8
AND189
Drives: 2
yeh see your point the best you can do is swap with a mate and see how they go... are you in sydney ??
Old 04-06-2010, 07:56 AM   #9
hazzy
Drives: Yaris YR
Yeah im in sydney
Old 04-06-2010, 07:57 AM   #10
AND189
Drives: 2
well i may be able to get a set of 17" for you to try for a bit let me make some calls if your keen
Old 04-06-2010, 08:08 AM   #11
hazzy
Drives: Yaris YR
Thanks for the offer, i may take it up in the future, however now is not really the time, thanks for your help
Old 04-06-2010, 08:09 AM   #12
AND189
Drives: 2
let me know buddy even if you just want to meet up my gf well gf in the works has one to
POLL: All things considered, what's the best wheel size for the Yaris? Kal-El Wheels, Tires and Suspension Forum sponsored by The Tire Rack 43 01-28-2014 10:29 PM
hub centric rings & Exel wheel - what size Mead Wheels, Tires and Suspension Forum sponsored by The Tire Rack 9 08-02-2007 02:02 PM
Does wheel size effect performance? Push Performance Modifications 20 07-13-2007 09:16 AM
Wheel size affecting speedo mikeukrainetz Wheels, Tires and Suspension Forum sponsored by The Tire Rack 5 06-13-2007 03:50 PM
