Old 07-31-2007, 06:12 PM   #1
Mead
Drives: BSP Yaris LB 2007
hub centric rings & Exel wheel - what size
anyone have Exel brand wheels?
what size hub rings for the Yaris?
and where's the cheapest place to buy?
Mead is offline   Reply With Quote
Old 07-31-2007, 09:02 PM   #2
DJ_SpaRky
Resident Scion Guy
DJ_SpaRky's Avatar
Drives: 2008 Mazda3 S Sport
Most likely 54.1 to 72, they are the most common for Toyota with aftermarket wheels. Look on TireRack or Discount Tire, they will help you out.
Code:
DiabolicJourney_SpaRky
DJ_SpaRky is offline   Reply With Quote
Old 07-31-2007, 10:12 PM   #3
Mead
Thanks
Old 08-01-2007, 12:17 AM   #4
Black Yaris
der Zeck
Black Yaris's Avatar
hub centric wheel are either given or sold with the wheels by the manifacture of the wheels..... discount tire has an "install package" that you can buy that has everything you need... most wheels you are not going to need hub centrics on the yaris, unless you get shit as wheels... even my knock-offs, of a knock-off do not need hub centrics.... you would have to have about $10 a piece wheels hand crafted by a blind man to need hub centric
Old 08-01-2007, 01:45 AM   #5
Sabretooth
37HSSV
Sabretooth's Avatar
Drives: '11 Mazdaspeed 3
Or if they are OEM from another automaker other than Toyota
Old 08-01-2007, 07:35 AM   #6
DJ_SpaRky
Resident Scion Guy
DJ_SpaRky's Avatar
I used to think the same thing until I got some. Big difference, it fills the space between the wheel & the hub, so that the wheel doesn't move around, because no matter how hard you tighten them, they WILL move.
Code:
Old 08-01-2007, 07:41 AM   #7
Black Yaris
der Zeck
I used to use hub centrics, untill I relized you don't need them on a quality wheel.... I have owned MANY sets of wheels in my time, and have sold god knows how many with and with out hub centrics.... they just make it a little easier putting the lug nut on, that is all... no other advantage
Old 08-01-2007, 11:03 AM   #8
kimona
kimona's Avatar
Drives: 2014 White VITZ
I wouldn't rely on a lugcentric application; use hubcentric rings.
Old 08-02-2007, 12:12 AM   #9
seanele
seanele's Avatar
Drives: '07 Blazing Blue LB, '09 Jetta
you will find complete line of Exel models at wheelmax.com,
but be aware that many complaints made due to the quality of Exel wheels.
they tend to break apart in pieces with no contact or accident at all.
i've seen the pictures and read stories about this in Nissan forum.
but I still like Exel designs though..they all look very nice.
current: '07 Yaris LB - '09 VW Jetta
ex: '06 Beetle S(19x8.5 Audi A8) - MK4 GLi BMP(18x8 OZ, K04) - '03 GTi(17x7.5 Ronal, APR93) - '01 GLS - '88 GTi - '86 GTi - '83 GTi
seanele is offline   Reply With Quote
Old 08-02-2007, 02:02 PM   #10
cm07yaris
Drives: 2007 Toyota Yaris Blazing Blue
Send a message via AIM to cm07yaris
I paid over a grand for my wheels and they came with hub centrics...
cm07yaris is offline   Reply With Quote
Does wheel size effect performance? Push Performance Modifications 20 07-13-2007 09:16 AM
Wheel size affecting speedo mikeukrainetz Wheels, Tires and Suspension Forum sponsored by The Tire Rack 5 06-13-2007 03:50 PM
steering wheel hub adapter yrsdrgn Cosmetic Modifications (Exterior/Interior) 0 02-25-2007 11:14 PM
