![]() ![]() ![]() ![]() Drives: 2009 Meteorite 3dr Join Date: Jul 2009
Need Serious Help! No Radio!!!
Ok, this is very serious. I was installing some LED's in the control knobs tonight and one dropped behind the the control knob area under the radio. When I reached in to pull it out the radio just shut off. It will not come back on at all.
it did not feel like I pulled out any wires or anything and I've checked all the fuses and they all look good. I don't know what to check next, this is not kool at all. I commute an hour to work everyday and have got to have my radio.Everything else is working fine and lighting up fine. I get light behind the knobs and buttons on the radio but nothing on the display and obviously no music or anything. Please please please please please help!
Touchscreen DVD Navigation - 10" Bazooka Subwoofer - Kenwood Speakers - Toyota Premium Horn set AFE Pro Dry Air Filter - modified air intake box - 1ZZ-FE Throttle Body - Ultra Racing Rear Sway Bar & Front Strut Bar NST in cabin & engine bay SSK's - TWM shifter base bushings & cable bushings - Megan Racing C-Pillar Brace |
I would pull the radio and check the connectors. The harness is pretty tight and you may have pulled against it just hard enough to shift one of the connectors, if it wasn't fully seated.
The other thing to check are the dome and ACC fuses. Sometimes when the low amperage fuses blow, it is not obvious with looking at them. If you have a multimeter, check the fuses for continuity. If you don't, try swapping those two fuses out, one at a time. |
thanks bro. I've never pulled the radio yet so that'll be another adventure for me.
Reluctantly Crouched...
Drives: 2008 Yaris HB M/T Join Date: Oct 2008
I'd bet its just a loose plug. you have to pull pretty hard to tear a connection, but it is possible to pull a wire loose from its spot in the plug assembly. also, if you short out the antenna, it might blow a fuse.
It is really easy to unsnap the climate controls too, which allows you to reach into that space easily. The radio (and everything else) comes out of that dash very easily, so don't be afraid to take parts off when working in there. |
Fixed it. It was a lugnut. thanks guys.
| radio wire colors & alarm wire color reference guide | battleversiontc | In Car Entertainment + Electronics (audio / video / alarm) | 43 | 06-06-2023 03:12 PM |
| 2002 Japanese Imported Vitz – Standard Radio Question | 2002vitz | In Car Entertainment + Electronics (audio / video / alarm) | 7 | 05-29-2013 10:06 PM |
| ATL, I want to trade my Upgraded built in radio... | matthewallanstill | Southeast | 2 | 03-28-2009 07:29 PM |
| Mounting a CB radio somewhere | Sodium Duck | Cosmetic Modifications (Exterior/Interior) | 1 | 03-06-2009 02:50 AM |
| I want to trade my Upgraded built in radio... | matthewallanstill | Items for Sale by private party | 0 | 09-03-2007 10:50 AM |
