![]() ![]() Drives: '07 YR 3dr Join Date: Jul 2007
Speed signal wire
Anyone know which wire leading to the OBDII connector/port is the speed signal wire?
Cheers
"I drive a silver egg" "Huh?" "An egg... You know; pretty much round, but with a pointy end; jeez..." |
you mean car speed or engine speed?
if you are looking for vehicle speed the only one i was able to find was the signal to the speedometer, heres the link for the repair manual, is on pages 226 and 227. http://www.etimago.com/yaris/repairmanual/EWD.pdf and heres the pic for the tach/engine speed. Last edited by joey1320; 09-17-2007 at 05:01 PM. |
![]() Drives: yaris Join Date: Mar 2007
trying to bypass the speed cutout?
Heh not really. I have an APEXi Rev/Speed meter that I've currently got hooked up to display revs and g-forces (front/back and lateral), and was just thought if it was easy enough I may as well give it a speed input so I can record and replay laps at the track...
![]() ![]() ![]() Drives: 3-door liftback blazing blue Join Date: Oct 2006
this will tell you where the vss wire ishttp://www.thecruisecontrolstore.com/newyarisinst.pdf
07 yaris LB 5-speed blazing Blue 07 yaris LB Auto Bayou Blue rostra cruise control oem style foglights 96tacoma 4x4 xcab I4auto Weathertech vent visors Scan GaugeII |
![]() ![]() ![]() Drives: Yaris Join Date: Nov 2008
i just got an RSM. Hooked it up, but the RSM isn't getting any signal. Spliced into PIN 26 (Purple) which is supposed to be the VSS. Can anyone confirm if its the right wire? Maybe i have to change settings on the RSM itself.
Anyway. Had a look into the Manual. Found a working speed sensor wire which connects to the instrument cluster 24pin plug. Its pin 17 (pink).
AKA Samurai Racer
where on the OBD2 port connector can i find the speed signal wire ?
![]() Drives: '06 Yaris Hatch and TT 300ZX Join Date: May 2009
It's not on the OBD2 port connector. The OBD interface sends serial data, there aren't individual wires for different sensors. You'll need to get the speed signal from the cluster loom or ECU loom.
![]() '06 LB 2NZ-FE w/ NST crank pulley "No RWKW" | '89 2+2 VG30DETT Z32 300ZX "Lots RWKW" ;) |
AKA Samurai Racer
ahhh. i thought maybe where i got the Tach wire signal from , there might be a wire i can piggback off. then how does the Scangauge get speed data from the OBD2 port ? must be one of those wires sending speed info ?
#11 | ||
![]() As mentioned in lunjiaow's post, he got the speed signal from the pink wire going to the gauge cluster. You'll need to find the wire going to the gauge cluster with the tach signal for your application. For reference, the common wires in the OBDII connector are simply 2xData, 1xground and 1xpower. The scanguage reads the serial data and processes it for it to display to you.
AKA Samurai Racer
ahh ok cool !! thanks alot buddy !! appreciate the help ! will have a look for that illusive pink wire , hehe !!
![]() ![]() ![]() ![]() Drives: 2008 Yaris HB Join Date: Oct 2008
Hooked up Avic D3 today in 2008HB and the pink wire in the speedo harness,is indeed a god wire to hook to for speed pulse,navi is now learning....hope this confirmation helps other looking for the VSS wire in an easy place.
| DIY: Replacing Stock Mirrors | redyaris | DIY / Maintenance / Service | 30 | 04-20-2016 03:03 PM |
| ICE Navigation Wire Question? | duck | In Car Entertainment + Electronics (audio / video / alarm) | 11 | 10-25-2008 12:20 AM |
| Speed Wire? | R0ME0 | General Yaris / Vitz Discussion | 2 | 04-26-2007 01:44 PM |
| Signal electrical questions | Blenjar | In Car Entertainment + Electronics (audio / video / alarm) | 3 | 01-19-2007 01:06 PM |
| Harman Kardon Drive + Play for IPOD | sroberts | In Car Entertainment + Electronics (audio / video / alarm) | 5 | 07-01-2006 01:05 PM |
