Old 06-14-2010, 12:32 AM   #1
2manywheels
Drives: 09 YarHB
Simota CB-314 Intake questions
Pulled out the stops to install today. :(
No pretty instructions inside the box(amongst all the popcorn bits)
Removed the stock goods, looked at the picture on the Simota website.
??--- The mushroom airfilter is mashed up against the plastic(near the drivers side headlight enclosure).
Is it supposed to be this tight? I snugged up(pushed that is) the rubber connects as much as possible.
The "support like" looking piece of metal.. Is this to be put under the intake and attached where the stock airbox was? if so do you need to get a bolt for it? the one that was there to hold the stock airbox is far to long for this to work.
One other concern: I logged some data for about 20 minutes with the stock airbox on, and then the Simota.
The intake temperature is almost 20-25 degrees higher.... should it be this high?
Thanks guys!!
TMW
Last edited by 2manywheels; 06-14-2010 at 12:35 AM. Reason: forgot top add a question!
2manywheels is offline   Reply With Quote
Old 06-14-2010, 11:21 AM   #2
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
take a picture of the problem. Might be easier to solve that way.
Old 06-14-2010, 01:16 PM   #3
2manywheels
Drives: 09 YarHB
I'll swing over to the parkade over lunch and take a pic.
THX
Old 06-14-2010, 04:29 PM   #4
2manywheels
Drives: 09 YarHB
pics of install
Simota
Old 06-14-2010, 04:39 PM   #5
Bluevitz-rs
I don't know? Looks good to me. How squished is it? Is there a bracket holding it there or is it wedged in there?
Old 06-14-2010, 06:11 PM   #6
2manywheels
Drives: 09 YarHB
Good Ole Wedgie... its snug.. enough that it changes the shape of the filter.
What about Intake Temp? Should it be that high... or.. Do you think it should be that high?
I like the office manager breathing warm.. but.. not sure the yaris likes that..
Old 06-14-2010, 07:01 PM   #7
marcus
toyota
marcus's Avatar
Drives: 2007 Yaris RS Blazed
turn the whole pipe clockwise/counter a bit so the nose goes up a little..
Old 06-14-2010, 07:19 PM   #8
2manywheels
Drives: 09 YarHB
I was going to try that, but thought the angle should match that of the throttle body area. It is angled upwards to wards the hood. Soooo.. I installed with the same angle. Just didnt want the intake tube touching the alumimum of the throttle body intake area....
Probably using all the wrong terminology.. LOL
Old 06-15-2010, 12:20 AM   #9
3stars_n_a_sun
3stars_n_a_sun's Avatar
Drives: 2008 yaris sedan
wow that's a tight fit. am wondering if that also will happen to the sedans.
3stars_n_a_sun is offline   Reply With Quote
Old 06-15-2010, 04:36 PM   #10
darkmoon87
darkmoon87's Avatar
Drives: 08 Yaris
i have a sedan and it's a really tight fit as well. had it for over a year without any problem though. a metal bracket came with it but i wasnt really able to find where to bolt the bracket onto so i didnt bother.
filter itself is tight but it is still in its original shape (no pun intended) and not squashed or anything.
RIP Yaris, I will miss your superb handling a lot.
darkmoon87's picture thread
http://www.yarisworld.com/forums/showthread.php?t=10013
darkmoon87 is offline   Reply With Quote
Old 06-18-2010, 12:37 AM   #11
msfire671
ONE LOVE...YARiS LOVE!!!
msfire671's Avatar
Drives: Toyota Yaris
Send a message via MSN to msfire671 Send a message via Yahoo to msfire671
hey darkmoon, think you could post some pictures? i would also like to get one cuz my weapon r filter fell off twice...and i could get myself a birthday gift as well...thanks =)
msfire671 is offline   Reply With Quote
Old 06-21-2010, 03:52 PM   #12
2manywheels
Drives: 09 YarHB
Besides the fit, I am concerned about the high intake temperatures with it installed compared to the stock airbox.
I may pickup the afe unit as it has the shrouding around it that seals up at the top of the hood. Could also put some insulative foil at the same place where it seals. Just in case the hood is hot, therefore increasing the intake temp.
Wallet hasn't closed in over a month.. haha
Simota intake commercial Red Horse General Yaris / Vitz Discussion 10 10-15-2009 08:38 PM
The great intake debate! fmicle General Yaris / Vitz Discussion 74 10-07-2009 12:37 AM
SIMOTA short ram intake... anubisx99 Items for Sale by private party 16 06-09-2009 01:40 PM
Simota Carbon Charger Cold Air Intake lilredrocket Performance Modifications 18 04-13-2009 04:16 AM
