I love momentum.
Planning first oil change @ 500 or 1000mi
As I've done with most of my new cars, I plan on changing the factory oil at 500 or 1000 miles. I feel that getting that break-in oil out asap is a good thing, and I find the motor gets quieter and feels nicer after that first change.
Can anyone give me a good reason not to change the oil that early? I'm assuming Toyota does not use some special break-in oil that I need to keep in there for the first 5000 miles. I plan on using Toyota oil for the first change (I know, I know, price gouging), then switching to another brand after. Thanks all! |
I believe it DOES have break-in oil with detergents to wear correctly during the first oil-change period.
there have been threads on this already |
I love momentum.
Reading some of the existing threads, this seems to be a point of contention for a lot of people. I don't want to open a can of worms.
I guess my only real question is whether or not the oil in the car from the factory is special or not. If it is, I'll keep it, if it's not, I'm going to change it out. Cheap insurance in my mind. |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2008 Yaris Liftback (Sprocket) Join Date: Oct 2008
Read and follow your owner's manual...
Learn to Relax
Drives: 2007, Meteorite, LB Join Date: Dec 2008
Change the oil after 1000 miles. It shouldn't make any difference.
I changed my oil after 500 miles. Then installed a magentic drain plug and powerful magnet on my oil filter. And changed it again in another 1000 miles. You wouldnt belive how heavy the oil filter was after 1k miles from all the metal wear particles trapped inside. And the magnet on the oil drain plug as well. If you have ever changed the transmission fluid on a honda that has a magnet on thier drain plug you know what i mean when i say it took several whipes of a rag to get it all off.
I think its a good way to extend the life of your oil pump. As well as cut down on engine wear. Little bit extra money but cheap insurance. |
On any car that I have purchased I have always changed the oil and filter at 500 miles, then again at 1500 miles, again at 3000 miles -- then kept them on 3000 mile intervals. Never changed oil without changing the filter too. I have never had any problem doing it that way over the years.
#8 | |
![]() ![]() ![]() ![]() ![]() Drives: yaris 08 sedan Join Date: Oct 2008
What?
Drives: 2007 Yaris LB Join Date: Nov 2008
Oil preferences and oil changing habits are one of the "holy wars" of every automotive forum. You'll never get a concensus.
I doubt that the factory fill oil is anything special, just bulk oil of the correct spec. I also doubt that there's any benefit to changing it before 5k miles, but do it if it makes you happy. I DO have an opinion on synthetic oil, however. Every engine needs to break in for optimal performance. If you switch to synthetic oil too soon, you stop or at least greatly hinder the break-in process (yes, synthetic oil is that good). If you're going to use synthetic oil, wait until after 5k miles to switch. Then (holy war point again), aside from the warranty requirement to change the oil at 5k, you can get away with 10k synthetic oil changes if you want. |
If the engineers who designed the engine say to change the oil at 6000 miles/10000kms thats good enough for me i'll presume they know more about the engine than i do .
#11 | |
I love momentum.
#13 | |
I know, I know... But I've always had good luck doing it this way. As for oil brands --- each to his own. I think any name brand is ok. I work in a fleet shop and have used the cheapest oil that is bid out. We change at 3000 miles and most of our vehicles go 2 and 3 hundred thousand miles without any engine problems. Now that's on the least expensive 5w30 oil that we can find.
#14 |
changed oil at 1000 miles and installed header/crank pulley at same time....
EVERYBODY EVENTUALLY COMES BACK TO YARISWORLD...... |
#15 | |
#16 |
![]() ![]() ![]() Drives: Yaris Join Date: Apr 2009
Dropped the oil at 1,000 miles and switched to synthetic. Changed again at 3,500. Now I will continue the synthetic regimen every 3,000 miles or 6 months (whichever comes first).
#17 | |
I personally would go back to 3000 changes myself.
#18 |
![]() ![]() Drives: 09 Yaris S 3dr Join Date: Mar 2009
Agree. My dealer had a new car buyer seminar and they stated any deviation from oil change recommendations can void lubricated parts warranty. For me, I'll be hitting 6 months with about 365 miles and I will be taking it in for scheduled maintenance.
| DIY: CHANGE MANUAL TRANNY OIL | ttufrosty | DIY / Maintenance / Service | 157 | 09-07-2018 02:43 PM |
| Help with oil change specs | autophile | DIY / Maintenance / Service | 31 | 04-25-2011 10:22 PM |
| Oil Change Issue. | Twistoffate0817 | General Yaris / Vitz Discussion | 56 | 05-05-2009 11:27 AM |
| Oil change time... yay! | YarisFan007 | DIY / Maintenance / Service | 10 | 09-19-2007 06:40 AM |
| Motor oil debate - interesting info but a long read. | mikeukrainetz | General Yaris / Vitz Discussion | 6 | 12-10-2006 09:16 PM |
