Hooch Brewer-Shine Sipper
Getting Rid of That Space!
I recently put on some 17-inch rims, but hate all that gap between the tire and the wheel well. I have a question about it.
Would it be possible to get a different tire size for the rim that would help take up all that slack space without looking ridiculous? That would be my alternative to lowering the car on the tires. Is something like that possible, and what would it look like? |
![]() ![]() ![]() ![]() Drives: 2010 Yaris S Join Date: Apr 2010
what tire size are you running right now?
"In his heart a man plans his course, but the Lord determines his steps." Proverbs 16:9 |
I'm in the same boat you are except I'm dealing with 16's. Trying to keep the same wheel diameter that was with my previous wheel package. It appears you might be running 30's or 40's. You could always go up (45/50/55/60) as far as tires go or just plan on some kind of lowering with either a spring/damper kit or coilovers. I wouldn't know about the look as far as the tire wheel combo but those seem to be the only solutions to your dilema as far as decreasing gap that I can see.
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: '08 Yaris Join Date: Oct 2008
It is possible to fill it more with a larger profile but it will not eliminate the wheel gap and it will also raise your car.
I would just lower it. |
#5 | |
Only Happy When it Rains
Also using different size tires could mess up your speedo and odometer, and will of course change how your car handles as well. With the MI springs being so inexpensive, they are a natural fit.MI springs.
Colin Chapman disciple |
Thanks for the info. Idiot me thought when I changed from the stock 14's to the 17's that the tire would fill in that gap. Of course, with a low-profile tire that doesn't happen.
I will check into those springs. Another ? How much to lower safely? I had been reading 1.5 inches or 2 inches. What about load? If I get 4 people in the car, are the tires gonna rub? :/ |
Okay, sorry. I clicked the springs link and saw it was 1.75 inches. But still, how about load? Obviously I have never done these things to a car before.
Most of that depends on the width and offset of your wheels, and also tire size.
If you let us know these, we can let you know if you will rub or not. |
You haven't indicated your current tyre size.
Sorry again, they are 205/40R17
On stock suspension, 205/40's look ridiculously short. Toyota OEM 17's are 205/45's.
Many people install 205/40's when upgrading because they are dirt cheap compared to 205/45's... and they fit quite well with a significant drop. But, with a mild to moderate drop, I think 205/40's are still too short. In Japan, Vitz enthusiasts sometimes install 205/50/17's on stock suspension... and although they are a bit tall, they look good and apparently work well unloaded. |
My bad on the profile thought as I didn't think about what happens on top also occurs at the bottom. Ding.
What 330H said, offset is an important number to know I found out. |
![]() ![]() ![]() ![]() Drives: 2008 Yaris LB Join Date: Jul 2010
205/40's work well on 17's with any drop, from 1.1" to 2.0".
#14 |
Thanks for the responses.
So, if I go with 205/50/17's then I won't need to lower? And if I do go that 1.75" lower the 205/40/17's I have now will look okay? |
#15 |
You'll still have wheel gap. Only way to get rid of it is to go lower.
Here are 205/50/17's on a stock Yaris sedan. ![]() ![]()
#16 |
Thanks for the pics. I see with the 50's there is more sidewall, right? Okay.
#17 |
lol, double confirmation
#18 |
![]() ![]() ![]() ![]() ![]() Drives: Scion FRS RS2, ‘21 Crosstrek Join Date: Oct 2008
Lowering is your best resolution.
Taller than stock tires may fill the gap however IMO the negatives are considerable. More overall wheel weight brings slower accelleration, decreased brake effect and a raised are never handles as well. On the good side those tall speed bumps will be less of an issue.
TRD Upgrades: 18" Wheels wrapped in 215/35/18 PZero's, Sportivo Shocks/Struts, Lowering Springs, Swaybar, Axle-Back Exhaust, Oil Cap, Rad Cap, Signage. Aftermarket Goodies: Piggies SS, K&N Drop-In, Blitz S/C, DC Header, NST Pulley) Toyota Options/Accessories: Sport Pedal Covers, Sport Shift Knob, Ipod Interface, Summer Mats, Winter Mats, Cruise Control, Auto-Dim Mirror, Echo steelies with winter boots.
| Ooopps... new space propulsion method | GeneW | Off-topic / Other Cars / Everything else Discussions | 2 | 04-17-2009 11:06 PM |
| Get rid of the vertigo stock susp. w/out lowering much | regal | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 5 | 03-13-2009 01:31 PM |
| DIY: Crosspost of how to get rid of DBW Lag! | Nexus1155 | DIY / Maintenance / Service | 7 | 09-14-2007 01:26 AM |
| Toyota Auris space concept | Fer.pa | Central and South America | 9 | 06-26-2007 02:45 PM |
| Enough Space? | soros151 | Performance Modifications | 24 | 07-21-2006 02:43 AM |
