Old 03-12-2009, 09:55 AM   #1
regal
Get rid of the vertigo stock susp. w/out lowering much
After driving a koni'ed '93 civic for 10 years my new Yaris with its stock mushy bouncy suspension gives me vertigo. Literally sea-sick. Now the Civic was lowered too much to be practical, I couldn't get her up the incline to my garage and I couldn't drive her in the snow.
I like a tight harsh kidney jarring go-cart track suspension, just can't take the bouncy "at sea" suspension Toyota came up with.
I need to drive this neat little Yaris in the snow so I really don't want to lower her much.
Are there any matched spring/shock packages that have just a minimal lowering but get rid of the bouncy bounce?
Old 03-12-2009, 12:35 PM   #2
fuji
fuji's Avatar
Drives: Polar White Yaris HB
Probably the cheapest way would be just to change you shocks while retaining your stock springs.
Probably the best solution would be a fully adjustable coilover. Just make sure the dampening can be adjusted.
fuji is offline   Reply With Quote
Old 03-12-2009, 12:46 PM   #3
CASTREX
Who said Yaris was slow?
CASTREX's Avatar
Drives: Yaris T-Sport 2008
For the smallest drop and improved handling you are looking for the TRD shocks and springs combo. Plus the TRD rear sway bar. That should make you happy.
A cheaper alternative for that set up would be:
Tokico HPS (Blues) + Tanabe NF springs + Ultra rear sway Bar
Also, pick up a set of front camber bolts. For like $20 bucks those would allow you to run a little bit of negative camber up front. And will improve your handling with minimal compromise on the tire wear
Old 03-12-2009, 01:20 PM   #4
MUSKOKA800
MUSKOKA800's Avatar
First, add at TRD swaybar.
You'll be shocked at the improvement in both handling and road manners with no noticable ride quality sacrifice and stock ride height. I had mine in four about a month prior to installing the balance of the TRD suspension components.
Old 03-13-2009, 01:09 PM   #5
regal
I think I am going to sell my old civic and buy the TRD suspension, sounds like it is much firmer than stock. The blue shocks look like a nice way to save $100 but I like the idea of TRD's toyota engineering.
Another question, would it be possible to find a winter tire size for the 15" steelies that would effectively raise the vehicle back up to stock heigth ( with the TRD springs) ?
Old 03-13-2009, 01:31 PM   #6
MUSKOKA800
MUSKOKA800's Avatar
The TRD spring/shock combo offers quite a bit stiffer ride. It's far, far from stock ride comfort. That said, it rails the turns which is what I like.
Regarding taller winter boots. You may find wheelwell clearance issues in the front. I have shorter than stock snows and still find the front wheelwells get packed with snow/slush/ice quite quickly. I'll be happier next winter just finding some snow's that bring it up to stock tire diameter, just for the ground clearance. My front lip should get a commission from the city for helping plow the streets.
