Drives: Toyota Yaris III 1.33 Join Date: Sep 2013
Idle rotates failure?!
Hi
I'm writing on this forum from Poland because on our forums I can't find any reasonable responses. Two months ago I bought brand new Toyota Yaris third generation with 1.33 engine and 6 speed manaul gearbox. First month of car usage was deprived out of any worries but a few days ago i observed that engine rpms when car stops on traffic lights or in garage are randomly stayed - usually between 800 and 1000 rpm (on warm/hot engine) Sometimes just after stop rpms a re stopped @ 980, then goes down to 900 and goes back to 900rpm. Is it proper ? Tomorow I will goe to my dealer to diagnose that issue. |
![]() Drives: Toyota Yaris 1.33 DUAL VVT-I 2 Join Date: Sep 2013
Hi,
Did you get any answer from your dealer ...... I have the problem present in my post ...... Toyota Dealer checked and diagnose was very good but the idle is not smooth and the car has a little vibration at idle. I guess we have consider this as normal::(( 1.33 VVT-I/2012 owner. |
#3 | |
![]() ![]() Drives: Yaris 1.33 litre 2011 Join Date: Dec 2009
Regards Geoff Peace. |
Hi,
Did you get any statement from the dealer related on your issue ? |
The IDLE does fluctuate when AC is on though.
It also fluctuates when the radiator fan turns on and off. |
![]() ![]() ![]() Drives: 2009 yaris 2 door Join Date: Feb 2013
Idle
Hey you are doing good if yours is Idling at 800+ rpm. Mine go's down to 500-400 sometimes but it always fluctuates with A/C on or off .To answer your question, yes it's normal to fluctuate.
it really depends on the engine's temperature.
mine does around 800 when AC on, and i'm around 650rpm when engine is fully warmed AC off. I'm often around 900 when the COOL light just turned off, but in reality, engine is not fully hot. |
My engine 1nr fe 1.33 VVTI Yaris 2012 has a vibration at idle.... please check my post ..... Dealer checked engine with OBD but no errors in history car..... anyone experienced this before?
| DIY - 1.8L 1ZZ-FE TB Connector Chip Swap | Yaris T-Sport | DIY / Maintenance / Service | 332 | 04-03-2022 01:39 AM |
| 1.33 DUAL VVT-I 2012 Toyota Yaris Vibrating at idle | cosmin1984 | DIY / Maintenance / Service | 16 | 02-10-2014 12:37 PM |
| rough idle.... | dindy | Third Gen Yaris General Discussion | 5 | 06-12-2013 12:48 PM |
| 3rd gen 1zz tb swap | mr_miles | DIY / Maintenance / Service | 26 | 05-01-2013 08:20 AM |
| Help with low idle from Venezuela | Yarisvene | DIY / Maintenance / Service | 5 | 06-23-2007 08:23 AM |
