Old 07-28-2010, 12:24 PM   #1
Admiraak
Drives: 2007 Yaris Sedan
225/50R15 Kumho Tires 15x6.5 Speedy Rims
I have a small problem. I bought these tires on Kijiji for such a good price that I couldn't turn it down. Now that I have put them on the car I have a problem with rear fender rubbing going over larger bumps. And having anyone in that back seat is just not an option.
What is the best option to help me keep these tires on my car? Stiffer suspension? Stiffer shocks? Air bag ride helper?
I haven't done any modifications to this car. The cheapest route would be great.
Any input would be greatly appreciated.
2007 Toyota Yaris Sedan.
Admiraak is offline   Reply With Quote
Old 07-28-2010, 12:51 PM   #2
ddongbap
I think it'll be cheaper to just buy new tires.
Old 07-30-2010, 07:37 PM   #3
33OH
Drives: '08 Yaris
+1. And since they're good tires, you can just sell them and buy another set of used tires in the right size without losing much money.
Old 07-28-2010, 01:26 PM   #4
You can try adding some rear camber. Cheap and easy. Go to Home Depot or similar store and buy 4 1/2" stainless steel washers. Place one of these on the lower two hub bolts between the axle and the hub. If it still does not provide enough clearance, then atleast you are only out a couple bucks and some of your time.
This took care of a rubbing issue that I had due to the right rear wheel on the car sitting 3mm more outboard than the left.
Also, do you know the offset of those rims. That would help us determine how far out your wheels are sitting, and better understand your particular clearance issues.
Old 07-29-2010, 12:03 PM   #5
Admiraak
The offset on the rims are 38. As for new tires what size is recommended?
Old 07-29-2010, 12:32 PM   #6
auxmike
auxmike's Avatar
How much did that setup cost ya?
Old 07-29-2010, 12:35 PM   #7
225s are pretty wide for a 6.5 rim. Better fit would be 195 to 205s. With the current 225s on a +38 wheel, adding camber may provide for enough clearance to eliminate the rub.
Old 07-29-2010, 03:46 PM   #8
Admiraak
$550...Like I said smoking deal...95% tread on tires too.
Old 07-30-2010, 09:46 PM   #9
ddongbap
550? I wouldn't exactly say that was a smoking deal.
Your gas mileage is gonna go down down down.
Old 07-31-2010, 12:55 AM   #10
auxmike
auxmike's Avatar
Agreed. I just bought a set of four 15" OEM 7 spoke wheels with tires already mounted for $600 delivered. ......And rims/tires are all brand NEW!
Old 07-31-2010, 10:45 PM   #11
Admiraak
Thanks everyone for the responses. I think I am just going to go with a new set of tires. I don't really want to mess around with the camber.
Old 08-10-2010, 08:39 AM   #12
MUSKOKA800
MUSKOKA800's Avatar
205/55/15 will put you right into the OEM size ballpark. Check the 'tire and wheel' guide which is stickied at the top of this forum for other acceptable choices.
Can I use stock tires on these 15" rims? songa Wheels, Tires and Suspension Forum sponsored by The Tire Rack 11 02-18-2009 07:11 AM
F/S MUGEN RnR 15x6.5 / KUMHO tires with about 1000 miles smokinyaris Items for Sale by private party 31 10-01-2007 12:20 PM
FS: 07 yaris RS stock rims n tires thegame11 Items for Sale by private party 5 04-15-2007 01:25 PM
