AC Not Working: What Should I Do?
2009 hatchback, 44 k miles. I seldom use the ac, mostly in winter for defrosting.
Is there anything I can check myself? How does one troubleshoot the ac and what tools are needed? Thanks!
Synthetic Oil: Its All In Your Head Last edited by bronsin; 05-26-2016 at 06:09 PM. Reason: Change title |
Buy a pressure reading gauge, it will have a high and low side and allow you to see if you are low in coolant.
If you seldom us the a/c then changes are it is a seized compressor, but i'd first check the pressure of the coolant, this will also show if you have a leak. That is why a/c should be run every week or so even just briefly. Keeps the oil in the coolant circulation through the compressor so it doesn't seize
In winter it is but I'm not so good about summer.
Where do you hook up the gauge? Will the gauge show a bad compressor?
Checked my 2001 ECHO SERVICE MANUAL and first thing it says is check the sight glass for bubbles.
Yep lots of bubbles..
On my sight glass it say I should see bubbles after use, but i've never really been able to see them, I don't trust that thing all too much.
You hook up the gauges to the high pressure side I believe. Not 100% sure but there iis , few good videos online about it. It won't show a bad compressor per say but it'll help you point to that direction if that is in fact the issue
Toyota (TM) Shareholder
You have a couple options as far as a gauge. You can get a professional set that hooks up to both the high and low side or a can of Freon that comes with a gauge and hooks up to the low side.
Although technically a sealed system, over the years some Freon may leak out. I added a little Freon two years ago and has been fine since. Keyword is little, too much is real bad. If you go the Freon can route I would go no higher than the beginning of the green area on the gauge when adding freon. Look for one that has sealant and seal conditioner. Bubbles is generally a good sign as it means the freon is moving and hasn't all leaked out. |
Toyota has the Yaris. They're going to pull a vacuum on the system after sucking it dry and see if the vacuum holds. This is $190.
Hmm the classic deal is do this then the system runs dry and its mo money for another component. I ll let you know. I like pulling the vacuum and wait and see if it holds. Hopefully they wait a year or so.
As a side. I checked my a/c window after using it for 20mins. There was no bubbles and then I moved/tapped the viewing glass and bubbles appeared a stayed.
So I guess the bubbles do work but may need to be helpe with some movement for them to show
Huh well here's the deal.
Toyota call ED space and said they drained and filled the system and found no leaks . They want me to come back in 500 miles and check again for leaks. Im guessing they put dye in there in case it leaks. Seems like a possible setup for more work for them to do and get paid for. ![]() This is why you want to DIY but I'm to old for that anymore.
Yep they put dye in.
Also they did a 10000 mile inspection for free and found nothing wrong and wrote it up. I think they get $300 for that.
| Electronics randomly not working - NEED HELP! | scoobopdan | DIY / Maintenance / Service | 5 | 12-17-2015 08:25 PM |
| Remote Fob and Stereo Stopped Working after Fuse Change | Ruud | DIY / Maintenance / Service | 6 | 03-12-2015 08:15 PM |
| Electric Windows Stopped Working !?!? | MattyP | DIY / Maintenance / Service | 0 | 09-14-2010 08:20 AM |
| Working at Volkswagen | elsteverino889 | Off-topic / Other Cars / Everything else Discussions | 22 | 05-07-2007 08:29 PM |
