Old 03-11-2015, 09:32 AM   #1
Ruud
Drives: Toyota Yaris
Remote Fob and Stereo Stopped Working after Fuse Change
Guys..
I need help. I have a Toyota Yaris 2006 Model (well it’s the Mrs). I have had an issue with the cigarette lighter stopped working.. So after reading these forums I finally located the fuse location for the CIG Lighter thanks to you all. So the Cigarette lighter is now working which is great… however the remote fob is not working so I have to manually unlock/lock the car with the key and also the radio has no power as well as the internal door light which usually comes on when you open the door.
Just to explain this is what I did.. I opened the bonnet and located the fuse box, looked at the diagram and took a spare 15A fuse out (Blue). I did not touch any other fuses. I then located the internal fuse box behind the glove compartment and took out the CIG 15A fuse (which was blown) and replaced it with the spare fuse. Put everything back together chuffed with myself and walked away.. Trying to lock the car with the remote.. Not working..
I have checked all fuses and they appear to be fine.. I need help. The Mrs thinks I have messed it up.. I need help advice guys.
Thanks in advance.
Ruud is offline   Reply With Quote
fuses, remote control, stereo, yaris, yaris 2006
