![]() ![]() Drives: 2010 Yaris LB/5, 1996 Miata Join Date: Jul 2009
Center Cap Question
I'd like to replace my wheel covers with some chrome trim rings and center caps. How can I tell if these center caps would fit the Yaris's standard 15" steel wheel? http://cgi.ebay.com/ebaymotors/TOYOT...essories#rpdId
The Last Baron
Drives: 09 Polar White HB Join Date: Jun 2009
i may be wrong but i think those are for the alloy wheels not the steelies.
Sanction this outbreak, a Virus conspires. Single sparks are Spectral Fires! | UR 19mm sway | |
![]() ![]() Drives: 2 Yaris Hatchbacks Join Date: Dec 2006
I bought a couple pairs of this style center cap, one pair from this seller.
http://cgi.ebay.com/ebaymotors/1996-...Q5fAccessories The pair from this guy had 8 plastic clips spaced out evenly that held securely over the center protruding part of the 15in steel wheel. The other set I bought from someone else only had 4 clips, and was not as secure. I was happy with this look myself. I searched ebay for Corolla Center Caps. |
i will sell you all 4 of these caps for real cheap if you are interested.
#6 | |
![]() ![]() ![]() Drives: BSP Yaris LB 2007 Join Date: Apr 2007
Reluctantly Crouched...
Drives: 2008 Yaris HB M/T Join Date: Oct 2008
send a pm to lilredrocket on the trim rings...he has some on his that look good.
Mead you've been PM'd check please.
#9 | |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 07 Yaris 3dr LB (Bayou Blue) Join Date: Oct 2008
Here's another option. It's what I currently have setup on my car.
![]() They are the stock steelies(take off hubcaps).... with trim rings (can be found at any autozone/advanced autos/O' Reileys for about $10-11 per wheel... keep in mind that you need 15" sized trim rings or whatever size rim you have if your not sure buy one try it out and if it doesnt work take it back and get the next size up! Give your wheels a good ole scrub down before you put the trim rings on.... the key to this look is to keep your steelies as clean as possible. Once the rims and tires have been cleaned get youself some tire shine..... spray the tires AND a little bit on the rims... let the tires dry on their own but get a rag and smoothe out the oil on the rims so you dont get spots where the spray has dried. Now put on your trim rings.... align the holes with the air stem ;] As for the center of the wheels... you should already have chrome nuts... polish those suckers up.... and Personally I added "dust caps" from NAPA to the centers to clean up the look especially since the axle on the front wheels are visable. The dust or "center" cap is from Napa's Balkamp catalog # 730-2411 they are only a dollar or two per cap. When you get the caps they will be a little bit too large and will fly off... so you will need some 3m double-sided tape (home depot/lowes), one or two layers will do it... dont be shy with the stuff.... apply the tape on the inside of the cap... before putting the cap on... this will make it easier. Once the tape is on... press onto wheel... use a rubber mallet to get it all the way on there... (btw these are removeable but should stay on till you need them off... no need to take them off to clean your wheels. annnd..... wa-lah! your done.
-Jen <3 ![]() Quote:
Yar1s: that's the look I want! Thanks!
#11 | |
:) no probs.
Machinist
Drives: Yaris sedan 2010 Join Date: Sep 2010
Thanks YAR1S i definitly working to have this set up ready for winter ;)
Machinist
YAR1S, i'm searching and searching for the center dust caps and can't find it. Can you find some for me or buy me some and i'll pay you trough paypal? I like the fact they are chrome.
#14 | |
I ain't even mad
#15 |
Yes, they are the same exact ones I have on my Yaris.
http://www.yarisworld.com/forums/sho...ght=trim+rings |
#16 |
![]() ![]() ![]() ![]() ![]() Drives: it is kinda stock Join Date: Oct 2010
i got the dust caps but i dont think i put them on right
do they make a full cover that attaches with the 4 lug nuts? like on police cars http://cgi.ebay.com/ebaymotors/MAZDA...s#ht_942wt_941would these work |
| center caps for 15" steelies? | Lewis | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 20 | 07-02-2018 03:50 PM |
| Center cap for OEM alloy | SilverBack | Willing to Buy by private party | 2 | 06-04-2009 05:12 AM |
| Center Cap help | Brian | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 7 | 02-25-2009 08:18 AM |
| radiator cap question | mikenacarato | Cosmetic Modifications (Exterior/Interior) | 5 | 11-24-2008 04:27 AM |
| center cap removal | djfuji | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 2 | 02-23-2007 01:38 AM |
