Old 11-23-2008, 11:28 PM   #1
mikenacarato
SIPNDEW
mikenacarato's Avatar
Drives: 15 STI
radiator cap question
it seems the radiator cap for the yaris is a 1.3 kg cap. would it hurt to put a 1.5 on? i have an arc one here that is for my evo engine but will fit the yaris but its a 1.5. comments?
Old 11-23-2008, 11:55 PM   #2
Benggolf2
Benggolf2's Avatar
No problem, just make sure it fits properly (the distance from the top to the bottom where the rubber gasket is) should be the same otherwise your 1.5 kg cap will not function properly.
Benggolf2
Old 11-23-2008, 11:58 PM   #3
mikenacarato
SIPNDEW
Drives: 15 STI
but as far as the pressure rating goes i can go higher than rated but not lower?
Old 11-24-2008, 12:07 AM   #4
Benggolf2
Benggolf2's Avatar
Yes, you may. Raising the pressure rating just delays the system from boiling over. Unless you are racing or in the topics where high temperatures becomes a problem, it may not be necessary to do so.
Good luck.
Benggolf2
Old 11-24-2008, 12:08 AM   #5
mikenacarato
SIPNDEW
Drives: 15 STI
well i just checked and the top part is the same (it will fit and close) but the rubber part is wider than the toyota one so that part wont fit PROPERLY. i choose not to mess it up haha
Old 11-24-2008, 03:27 AM   #6
Benggolf2
Benggolf2's Avatar
Smart decision!
Benggolf2
Transmission Question CMR General Yaris / Vitz Discussion 42 04-14-2010 12:38 PM
Amplifier Watt Question....noob question hasher22 In Car Entertainment + Electronics (audio / video / alarm) 4 09-27-2007 03:59 PM
dealer trade-in payoff question.. kapo New YARIS Purchase Forum 1 07-16-2007 10:27 PM
Question about 2 kinds of TRD springs & rear strut bar Astroman Wheels, Tires and Suspension Forum sponsored by The Tire Rack 3 06-18-2007 05:44 PM
Tune Up Question? bestyaris DIY / Maintenance / Service 5 01-02-2007 09:09 PM
