Old 12-22-2006, 01:45 AM   #1
wushumasterku
Drives: 06 White LE HB 5spd
tanabe or trd
i'm really confused about which ones to get..
i'd like to get 15" rims after lowering my car.
the only reason why i would go for trd is because it would still be under warranty.. but i'm afraid trd would still be too much gap for 15" rims..
can someone advise me?
thanks in advance
wushumasterku is offline   Reply With Quote
Old 12-22-2006, 01:47 AM   #2
ever think about getting the Tein's?
Old 12-22-2006, 01:55 AM   #3
PetersRedYaris
PetersRedYaris's Avatar
Drives: 2005 Scion xB
Look for pictures posted of Yari lowered with Tanabe NF210's on stock 15 steel wheels. The NF210's drop the car 1.3 inches, compared to TRD's 1.2 inches. I think the DF210's are to low at 1.6-1.8 inches. If I were you I would go for the TRD's or NF210's, thats what I plan on doing next to my Yaris.
PetersRedYaris is offline   Reply With Quote
Old 12-22-2006, 01:59 AM   #4
wushumasterku
the DF210's, that's too low for 15 inch rims? i thought it was just perfect, because i saw pics of trd springs with 17 inch rims and it looks ok, so i figure 15 inch rims would still have some wheel gap. is that right?
Old 12-22-2006, 07:53 PM   #5
jcove
jcove's Avatar
Drives: 2011 Rogue
My thoughts exactly, but I'm not going to put down the DF's. Those just aren't for me.
jcove is offline   Reply With Quote
Old 12-22-2006, 01:57 AM   #6
wushumasterku
no, where can i get more info about them? any suppliers on here??
Old 12-22-2006, 02:01 AM   #7
bigsky2
Cousin Vitz
bigsky2's Avatar
Drives: Yaris RS 5DR / Vitz RS wannabe
This is what the car will look like after lowering with "TRD" springs (they're rebadged Eibach Sport springs) with 15" alloy wheels:
DIY Speaker Spacer/Bracket Template for Yaris Hatchback http://www.yarisworld.com/forums/showthread.php?t=1930
bigsky2 is offline   Reply With Quote
Old 12-22-2006, 02:05 AM   #8
wushumasterku
thanks bigsky, i was talking about your car in my post above.. i was gonna post a pic of it.. but then you replied here :)
that looks good, but if i was to get lower profile tires, then it could be a problem... or should i leave it around the same profile size as stock tires.. hmmm any suggestions??
Old 12-22-2006, 02:05 AM   #9
wushumasterku
the stock steelies are 14 inch am i correct?
Old 12-22-2006, 02:19 AM   #10
bigsky2
Cousin Vitz
bigsky2's Avatar
Yes, the steelies are 14".
Old 12-22-2006, 02:21 AM   #11
PetersRedYaris
15 inch steelies are also stock. I believe they come with the convienience package. Also, 185/60/15, not 185/65/15, are stock here in the USA. Both of you are from Canada however.
Old 12-22-2006, 02:09 AM   #12
wushumasterku
btw, here's a pic of my car
Old 12-22-2006, 02:09 AM   #13
bigsky2
Cousin Vitz
bigsky2's Avatar
I suggest caculating your overall stock diameter (wheel + tire), and then calculating the new overall diameter with your new wheel and tire setup.
For me, the stock setup was 185-65-R15, and the new setup was 205-40-R17.
I think there is a minor difference in diameter, and hence there is slightly more gap between the tire and my wheel well.
Old 12-22-2006, 04:00 PM   #14
Black Yaris
der Zeck
Black Yaris's Avatar
stock tires are larger in Canada? here in the states out stock size is 185-60-15 witch would translate to a 215-40-17
Old 12-22-2006, 04:18 PM   #15
bigsky2
Cousin Vitz
bigsky2's Avatar
Sorry, I screwed up the tire size there.
You are right, for the record:
15" Tire size = 185-60-15
14" Tire size = 175-65-14
Old 12-22-2006, 02:11 AM   #16
bigsky2
Cousin Vitz
bigsky2's Avatar
I think TRD (Eibach) springs have the least aggressive drop, which is about 1.3~1.5".
The Tanabe offers a more aggressive drop (the DF's I think, correct me if I'm wrong) and a less aggressive drop, NF's. The NF's are comparable to the Eibach/TRDs.
I do not know the drop of the Tein...
If you really want that "tucked" look, with absolutely no gap, I think the Tanabe DF + 15" rims (and proper tires) would look great.
Old 12-22-2006, 02:15 AM   #17
wushumasterku
any rubbing for that set up?
Old 12-22-2006, 02:20 AM   #18
bigsky2
Cousin Vitz
bigsky2's Avatar
There shouldn't be, provided you get same profile tires for the 15" alloys (185-65-R15) or lower profile tires for the aftermarket 15" wheels.
tanabe nf210 vs. TRD lowering springs?? static808 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 37 01-24-2012 12:00 AM
TRD OR Eibach...i'm confused... hoahmaru Wheels, Tires and Suspension Forum sponsored by The Tire Rack 39 11-07-2008 09:25 PM
Fs: New Trd Stickers & Emblems !!!!! located in So cal Trd86 Items for Sale by private party 13 06-25-2007 05:49 PM
TRD Parts MC-BPT Sponsors Classifieds Area 9 06-23-2007 11:51 AM
Toyota's Yaris TRD VitzBoy General Yaris / Vitz Discussion 10 07-24-2006 09:10 PM
