2ZR swap. DO IT! Ask how!
Part numbers for D10/D11 pins?
Hopefully CTScott has this info handy! I'm trying to make a harness for the DPS module and can't find anything about the pins for plugs D10 and D11. I ran the 5-digit part numbers on the plugs through toyotapartszone and found them, but there's no indication of the pins themselves online or in either the EWD or A/V repair manuals. The sockets will be from an aftermarket stereo adapter, and I have part numbers for the DPS end.
From a post I just read about someone who tried to order pins for D75/D79, it's cost prohibitive to get OEM pins ($12 EACH!), so any tips on secondary sources would be great. Speaking of D79, I don't even see it listed in the '07 EWD... |
Are you looking for pins to add to the D10 and D11 connectors, or pins to plug into the pins in the existing connectors?
Sorry for the confusion. I'm looking for the pins that mount in the D10/11 connectors. I basically need to replicate the existing plugs on a new wire harness. Maybe a diagram would be useful?
![]() The "new" D10/11 plugs are the only part that I can't get the internal pins for at the moment. Thanks! Last edited by CrankyOldMan; 07-23-2011 at 08:39 AM. |
#4 | |
By "good price" are you talking relative to the OEM price for the D74 connectors ($10+), or relative to some common pins from Mouser/DigiKey ($0.10+)?
The other thought I had was to find a local junker with the same radio plugs and cannibalize it. Since I'll be crimping the pins for the DPS connector on the other end of the wires, they can be pre-made, and it saves me the hassle of ordering the connector bodies online. |
#6 | |
The wrecker option is good. Also, there are aftermarket ones that are sold for installing a Toyota radio in something else. They run about $10.
My original idea was to scour mouser and digikey for them (since I've found other automotive connectors on them) but without a product line or manufacturer part number I've been stumped.
The Toyoya (Fujitsu ten)->other harness would be a great idea too. I'll see what I can come up with and let you know if I need the pins. Thanks again for your help. |
Here's one for the tC OEM stereo:
http://www.amazon.com/Stereo-Harness...452485&sr=1-93 I'm not sure if the picture is accurate, or if all of the pins are included, but it /looks/ promising. |
![]() ![]() ![]() Drives: 2009 3dr LB Manual Join Date: Mar 2010
Actually, here's a better price:
http://cgi.ebay.com/ebaymotors/ws/eB...3154&viewitem= I just got one of those a week ago, and it's great quality. Is that what you're looking for? Oh, and I did use that exact seller. Shipping was quick from California. CrankyOldMan, what part of West Michigan you from? |
#10 | |
I'm from the greater Grand Rapids/Grand Haven area. Perhaps you've seen me driving like I own an Audi? =) CTScott - I'm gonna pass on the pins for now. If it looks like I need to re-wire with longer wire I'll give you a PM. Thank you both for your help! |
I actually live in Holland, and go to Kalamazoo a few times a week. I stay on M40/89 most of the time. Always fun seeing more Yaris' in the area!
Awesome you got those. We'll be looking forward to your progress. Let us know if you've got anymore questions, or need a hand. |
CTScott - by any chance are these connectors the Sumitomo MT non-sealed line? http://easternbeaver.com/Main/Elec__...onnectors.html
Scroll to the bottom... Lil Abner - I don't usually get south of Port Sheldon, but occasionally go out that way for shopping. |
#13 | |
#14 | |
6-pos MT series ![]() 10-pos MT series ![]() The polarizing rib channels are both present (the OEM only uses one) but that doesn't matter in this case since they're going into the OEM stereo. The female sockets however won't work on the OEM wire harness unless one of the ribs is removed. |
This is what the correct ones look like from the side. Note how the male pin has the ribs on the opposite side and the female has them, but the pins above do not. The pins above may work, but my experience with various other Toyota pins is that even though they look mighty close, they end up not working. Either they won't insert all of the way in, or the pin lock won't snap back into place.
#16 | |
Maybe it's just more worthwhile to stick with the premade harnesses? |
#17 | |
So, the premade harness is your best bet.
#18 | |
The good news is that I can officially stop searching for those buggers. If I need to put in longer leads I'll definitely give you a PM for some pins. |
| Part Number(s) for '09 5-door LB engine air filter? | IsLNdbOi | DIY / Maintenance / Service | 5 | 01-02-2011 02:51 PM |
| 2008 OEM S model Liftback Lip kit Part numbers | PETERPOOP | Cosmetic Modifications (Exterior/Interior) | 17 | 07-26-2010 02:33 PM |
| need part numbers please help?! | kid chino | General Yaris / Vitz Discussion | 5 | 10-27-2009 03:27 AM |
| Rubber weatherstripping part numbers | The Spectacle | Cosmetic Modifications (Exterior/Interior) | 6 | 05-13-2009 07:40 PM |
| Help Finding part numbers PLZZZZ!!! | Duckywitbigfeetz | Cosmetic Modifications (Exterior/Interior) | 0 | 07-29-2006 03:21 AM |
