Old 12-31-2010, 11:24 PM   #1
IsLNdbOi
IsLNdbOi's Avatar
Part Number(s) for '09 5-door LB engine air filter?
I need to change the engine air filter for my '09 5-door LB. Anyone have the part number for the OEM Toyota filter or the part number for a 3rd party filter I can get from AutoZone or Checker's Auto?
Thanks.
Old 01-01-2011, 11:55 AM   #2
RedRide
RedRide's Avatar
I got an OEM Filter right in front of me and the number is: 17801-21050.
If you are interested in a K&N filter (I'm using one) the number is 33-2360.
Old 01-01-2011, 05:00 PM   #3
IsLNdbOi
IsLNdbOi's Avatar
Thanks!
Anyone have part numbers for 3rd party engine air filters that are available from AutoZone or Checker's?
I don't want to use K&N since I'm in a dusty region.
Also, is there a DIY on how to change the engine air filter?
Old 01-02-2011, 08:49 AM   #4
Happy Little Pony
Drives: 2007 Yaris HB
Originally Posted by IsLNdbOi View Post
Thanks!
Have you tried going to you favorite parts store's web site and looking up what you need? The Checkers/O'Reilly's web site says they carry a Wix 49104 and a Microgard 10190. Autozone carries the STP 10190.
A DIY would insult your intelligence. Just loosen the two metal clips that hold the air box tight, lift up the top a little and pull out the old filter. Put the new filter in oriented the same way as the old one. It is irregularly shaped and has a groove in it, so it only fits one way. Push the box back together, put the clips back on, double check to make sure it's on straight and tight all the way around and you're done.
Happy Little Pony is offline   Reply With Quote
Old 01-02-2011, 11:43 AM   #5
MadMax
MadMax's Avatar
Go to a Toyota dealership, they are less than $15...
And it is a simple replacement, remove the clips on the airbox, take out the old filter, put in the new one, and close. The filter has a small edge on one corner so it will only go in one way. Takes maybe a minute...
Cheers! M2
Old 01-02-2011, 01:51 PM   #6
slow.yaris
Drives: 07 yaris sedan
just ask them for an air filter... its not there gonna be like "a what? an air filter? what's that... do you have a part number?
slow.yaris is offline   Reply With Quote
OEM Engine Air Filter Parts Number? 2007yariz DIY / Maintenance / Service 2 12-05-2010 10:19 AM
Liftback Air Conditioning (Cabin) Filter info Snappy DIY / Maintenance / Service 24 10-01-2010 06:36 PM
Anyone have Yaris air and oil filter numbers? Yaris_Fan DIY / Maintenance / Service 54 02-11-2009 01:14 AM
Which Engine Air Filter to choose? YANGSTER Performance Modifications 16 09-29-2007 10:48 AM
