Old 01-27-2011, 03:54 PM   #1
LauraCow
Drives: Yaris
Drivers door wont open from the inside
I have a second gen Yaris and today the drivers door suddenly stopped opening from the inside, but I can open from the outside? I have done nothing wrong to it, as I had opened the door from the inside 10 minutes earlier.
Is this a known problem at all? Or is it just that I am unlucky?
LauraCow is offline   Reply With Quote
Old 01-27-2011, 04:04 PM   #2
Sounds like the child safety lock is on. With the door open, look just inside of the slit for the door latch, and you'll see the small lever.
Old 01-27-2011, 04:05 PM   #3
LauraCow
Drives: Yaris
On the drivers door? Didn't think this was possible?
Old 01-27-2011, 04:14 PM   #4
Oops - No that is correct, the safety locks are only on the rear doors.
The cable for the inside handle may be binding against the inside of the door panel. When the issue occurs do you feel resistance when pulling the inside handle, or does it move like it is not pulling against anything?
Old 01-27-2011, 04:30 PM   #5
LauraCow
Drives: Yaris
It feels as if theres nothing catching onto it. It feels like if you have the doors locked and try to pull on the outside it just goes up without resisting or anything.
Old 01-27-2011, 04:38 PM   #6
In that case, I do think that the cable is binding. The next time it does it, try pulling on the armrest and holding pressure on it before pulling the door lever. If that works, then it is definitely a bound cable, which means pulling the door panel off to find out the cause of the bind.
Old 01-27-2011, 04:53 PM   #7
LauraCow
Drives: Yaris
Just tried it, nothing at all. It's just all flimsy.
Old 01-27-2011, 05:12 PM   #8
yaris2010RS
yaris2010RS's Avatar
the cable is unlatched from the handle. take the screw out of the middle of the handle and pull out the handle and check if the 2 cables are attatched.
Old 01-27-2011, 08:42 PM   #9
+1. and that's an easy thing to check:
Name:  Door cables.jpg
Old 01-28-2011, 10:32 AM   #10
LauraCow
Drives: Yaris
I can't get at it without taking the door card off...
Old 01-28-2011, 12:06 PM   #11
The screw is under the handle. You can see the edge of the screw recess in my picture.
Old 01-29-2011, 11:52 AM   #12
LauraCow
Drives: Yaris
I've come to realise I have a 1st gen Tried taking the whole door card off, but it doesn't come off in the same way.
Old 01-28-2011, 11:22 AM   #13
marcus
toyota
marcus's Avatar
Drives: 2007 Yaris RS Blazed
the screw is behind the handle bars.
Old 01-29-2011, 01:37 PM   #14
Take a look at this thread:
http://www.yarisworld.com/forums/showthread.php?t=32976
Old 02-02-2011, 05:09 PM   #15
bankrobber
Drives: 2007 Yaris Hatchback
Just crawl through the window like the Dukes of Hazzard
bankrobber is offline   Reply With Quote
Wires Inside the Yaris & What They Do The Architect DIY / Maintenance / Service 149 10-18-2022 03:32 AM
HELP! - I Can't open my rear door - Any ideas? scorpio DIY / Maintenance / Service 2 09-25-2010 02:05 AM
Back door won't open from the inside ?! bnther36 General Yaris / Vitz Discussion 14 10-20-2009 02:04 PM
And the worst drivers in America live in..... KCALB SIRAY Off-topic / Other Cars / Everything else Discussions 12 05-22-2009 08:55 PM
Cannot open the driver door when unlocking from the outside. Rahxephon DIY / Maintenance / Service 10 12-02-2006 09:18 AM
