Old 11-28-2006, 01:13 AM   #1
Rahxephon
Drives: Vitz RS
Cannot open the driver door when unlocking from the outside.
There's a problem w/ my Vitz. This morning I unlocked the door using the remote. However, the driver door wouldn't open. I got inside my car using one of the back doors. The driver door lock was in an unlocked position; I could see the orange mark on it. I was able to open the driver door from the inside.
I thought the problem was temporary. However, it happened again after I got off work this evening. I still couldn't open the driver door (from the outside), even when the orange unlock mark is shown (inside).
I can still open the driver door from the outside, if the door is unlocked and then opened from the inside FIRST - then closed without (re)locking it. If the door is unlocked from the outside, without opening from the inside first, it won't open - even when the door orange unlock mark is visible. I hope this is not too confusing.
Any suggestions? Can I fix this myself? Will this be covered under a warranty? Thanks in advance.
Rahxephon is offline   Reply With Quote
Old 11-28-2006, 01:35 AM   #2
sounds like something mechanical is broken there, off to the dealer you better go... Or you could open up the door and take a look at it yourself!
Old 11-28-2006, 01:37 AM   #3
static808
Engineer/Artist/House-Dad
static808's Avatar
Drives: 2006 Toyota Sienna XLE
take the car in immediately, and just reproduce the problem for the technicians. i truly believe that cars are living beings, in that they absolutely KNOW when they are being taken in for warranty service. the moment you get your car into the dealership, whatever problem you had will no longer exist, just in time for the technicians to inspect it. and the moment you get your car in your driveway, the problem will manifest itself once again. if its still happening, take it in. hopefully your car will be obedient and show the problem to the toyota techs...
--B
His: 2006 Toyota Sienna XLE Arctic Frost Pearl, FC Package, 2007 Solara Nav unit, Spoiler, Running Boards & Auto-dimming rear mirror
Hers: 2007 Toyota Yaris LB Black Sand Pearl, Auto, Power Package, Side Airbags, VIP security, USDM center armrest, and accessory 7 spoke 15" alloy wheels
static808 is offline   Reply With Quote
Old 11-28-2006, 03:38 AM   #4
spkrman
Drives: 1
yep!
its normally not a big thing to fix, yank off the panel and have a look,should show ya whats up.
Old 11-28-2006, 02:25 PM   #5
hmm.. dude!! try unlocking the car with the KEY first?? don't use the keyless entry see what happens.
Old 11-29-2006, 11:40 PM   #6
Rahxephon
Drives: Vitz RS
Thanks all. The problem still existed this morning. However, it just went away on its own this evening. Hopefully, it doesn't come back. If it's still OK by tomorrow evening, I'll have to cancel the appointment I made w/ my local Toyota dealer. They said it's covered under the warranty, BTW.
Old 11-29-2006, 11:43 PM   #7
Rahxephon
Drives: Vitz RS
I did that and it didn't work either. You see, either opening w/ the remote or w/ the key, the red unlocked mark was displayed. The problem was that I couldn't open the door when it was unlocked from the outside. I had to open it from the inside by entering the car through the other doors.
Old 11-30-2006, 06:40 AM   #8
Violin
Violin's Avatar
Drives: 2007 Yaris LB Auto
I'd still let Toyota look at it. Mechanical problem don't usually heal themselves so you might as well have it repaired while it's still under warranty rather than have it fail later.
Old 11-30-2006, 10:55 AM   #9
the yaris is made so that you can ALWAYS open the door from the inside. lock or unlocked.
if it's locked, openning the door from the inside automatically unlocks the door.
Old 11-30-2006, 11:13 AM   #10
Not with mine but maybe it's a different system here with power doors...
Old 12-02-2006, 09:18 AM   #11
Rahxephon
Drives: Vitz RS
Thanks Violin. I might have that checked out when I take my Vitz for an oil change in January.
Please open the DOOR CAREFULLY! Rahxephon Off-topic / Other Cars / Everything else Discussions 34 12-21-2006 08:25 AM
