Old 02-21-2011, 08:19 PM   #1
yaris rs
Drives: 2009
yaris oversteering
based on my SIG. mods, I am able to oversteer when approaching limits of traction.
So my theory between the 19mm sway bar vs the 23mm bar and non-adjustable shocks is... 23mm will induce oversteer at a much lower limit (obviously) while the 19mm does too but at a higher limit. lets say for sake of arguement the 23mm will oversteer a flat 90* turn @ 15 mph while the 19mm will at 20 mph.
Now relevent to my setup which is adjustable shocks... you should be able to tune the suspension to set the 23mm to oversteer at a high limit (from 15 mph to lets say 23mph) by adjusting the shocks. Going from full stiff and lowering in .5 turn incriments should produce the most effective results for time. Conversely, the suspension can be dialed down to induce understeer with the 23mm as well. The whole adjustablity aspect will be able to change the limits of the car and alter its driving characteristics.
Point being, if you are looking for a fun time, tune-ability and traction, go with adjustable shocks. Swaybar will determine at what limit(s) the car will over/understeer. A smaller diameter will understeer with more "stiffness" (compression/rebound) in the shock compared to the 23mm, which will be able to at a lower C/R.
I'm taking the set up to its first autoX to test settings and driving and will post results =)
yaris rs is offline   Reply With Quote
DIY Cruise Control FAQ (2006-2010 Yaris) CTScott DIY / Maintenance / Service 468 11-19-2024 04:45 PM
Florida Yaris Meet! 6/23/2007! Sabretooth Southeast 13 06-05-2007 07:46 PM
