Old 09-06-2014, 01:27 PM   #1
HenryMak16
HenryMak16's Avatar
Drives: 2009 Toyota Yaris Hatchback
How do you exactly tune a yaris?
Was learning about air-to-fuel ratios and gave a local tuning shop a call. They said they don't have any software to get into the yaris' computer. Saying I need something aftermarket?
On another note, will tuning the AFR to stoich (14.7) on a bone-stock yaris benefit?
HenryMak16 is offline   Reply With Quote
Old 09-06-2014, 01:37 PM   #2
mitchell12
mitchell12's Avatar
Drives: 2007 yaris HB
Don't think any Toyota ECM's have really been cracked or the code released for them meaning they can't be reprogrammed. So yes, in order to tune you will need something aftermarket and unless you have a handful of boltons there isn't much point in a tune.
mitchell12 is offline   Reply With Quote
Old 09-06-2014, 01:42 PM   #3
xnamerxx
0-60 in slow
xnamerxx's Avatar
Drives: light blue liftback
The ecu can't be tuned since it
Hasn't been cracked but you can add a piggyback. There isn't much to gain from optimizing AF tables but optimizing cam timing is worth quite a bit of HP. The stock engine gains about 10 HP with a camcom.
Old 09-06-2014, 02:42 PM   #4
malibuguy
Obsessed with 1.5L
Drives: '10 PW Yaris Sedan
I thought the camcon was discontinued. ..?
-Greg...the Exhaust Freak.
-82 Malibu, 1uzfe swap
-97 Tercel coupe, 1nzfe/4.31
-96 Tercel 4dr
