I ♥ Yaris
Drives: Black 08 LB MT & red 97 Miata Join Date: Oct 2008
My Ultra Racing rear sway bar install
Well I finally got my rear sway bar from MicroImage (Thanks Garm!) I installed it the same day and heres the pics...
Before install ![]() Note that the sway bar is sitting on the ground facing the opposite way from when it is installed ![]() Back wheels off ready to remove the nuts ![]() Also note the jack under the shock to relieve the pressure so i could pull the bolt back far enough to put the bar on ![]() Right side installed ![]() Finished! This rear sway bar is really great! The car is a lot less nervous in corners. The back end used to tend to step out on hard turns, especially when hitting bumps. I had to learn not to adjust so much for that behavior. When taking the highway on ramp near my house, I'd take it a little shallow because the back would step out a little on the bumps, well first time or two, I took it almost too shallow! I'm used to it now, and the back end tracks very well, now. I'm very happy with my purchase!
The trouble with the world is that the stupid are cocksure and the intelligent are full of doubt. - Bertrand Russell Last edited by CtrlAltDefeat; 11-01-2009 at 04:59 PM. |
![]() ![]() ![]() Drives: ings 09 Yaris 3 Door LiftBack Join Date: Mar 2009
congrats
![]() I installed my rear sway 2 days ago, it's really funny
REAL JDM ings+1 Full Body Kit…REAL JDM C-One Spoiler…Retrofit Projector Headlight…Kiddo 6-pots BBK…CE 28N J-Time Attack…Bride Ergo II Racing Seat…Personal Steering Wheel…Work Bell Quick Release…Dealer Option Sun Roof…JDM RS LED Side Mirror…JDM RS Taillight…C-One Oil Cap…C-One Radiator Cap…TRD Iridium Racing Spark Plug…Tom's Fuel Map Controller…Blitz throttle controller…GReddy Informeter Touch…MR Suspension…TRD Rear Sway Bar…MR C-Pillar Bar…GTspec Front Strut Bar & Rear Strut Bar…AFE Intake…WR Header…Nitto Mid-Pipe…Greddy Ti-C axleback…Goodridge SS Brake Line… To do: Supercharger… |
#3 | |
I ♥ Yaris
The trouble with the world is that the stupid are cocksure and the intelligent are full of doubt. - Bertrand Russell |
37HSSV
I just installed mine today..My funny story: 19mm Sway Bar Install
Well I kinda confirmed the fact that this part CAN be installed without either jacking up the car, nor removing the tires. Why I did this, I wanted to prove what someone had said previously, and I really didnt feel like searching for the jack arm for my floor jack. Anyway, all went well, Sway bar installed, and I LOVE IT! Car feels totally crisp, allowing me to push the corner that little extra bit, or just allow the car to transition a bit smoother throughout the corner. I cant wait to get this baby to the track and start to mingle with the other cars.
07 Toyota Yaris Hatchback -sold- 11 Mazdaspeed 3 -SRI/TIP, 3 inch TBI, Custom FMIC, Tuned by Cobb Accessport, HKS ssq2 BOV, Upgraded HPFP- Clean stock look... Killer performance. Last edited by Sabretooth; 04-28-2009 at 01:31 PM. |
I love momentum.
^ agreed. I installed my TRD late last week and it was cake. I didn't jack the car up, didn't remove the tires. Just bolted it right on.
And yes, everyone should get a rear sway, even people who don't care about handling. It makes the car that much better. |
#6 | |
What?
Drives: 2007 Yaris LB Join Date: Nov 2008
If anything, adding or increasing the size of a rear swaybar (or otherwise increasing rear roll stiffness in any way) will tend to make the back end of the car "step out" (oversteer) more in a turn, not less. Remember, a rear swaybar is transferring weight from the outside rear tire to the inside front, it's giving you LESS grip in the rear... but that's generally not a problem in a FWD car. Perhaps you're referring to body roll? The car will certainly roll a lot less with more rear roll stiffness, and as you said, it will feel a lot more planted. BTW, Garm sells two different Ultra Racing bars, a 19mm and a 23mm. Which one is this? |
the bigger 23mm cause others would look up to you.....
EVERYBODY EVENTUALLY COMES BACK TO YARISWORLD...... |
![]() ![]() ![]() Drives: Silver 2007 3Dr - Gryph Join Date: Jul 2007
[QUOTE]
If anything, adding or increasing the size of a rear swaybar (or otherwise increasing rear roll stiffness in any way) will tend to make the back end of the car "step out" (oversteer) more in a turn, not less. Remember, a rear swaybar is transferring weight from the outside rear tire to the inside front, it's giving you LESS grip in the rear... but that's generally not a problem in a FWD car. Perhaps you're referring to body roll? The car will certainly roll a lot less with more rear roll stiffness, and as you said, it will feel a lot more planted. [QUOTE] I think he means he used to specifically push it into understeer on the on-ramp, and would aim 'too shallow' to compensate. He has enough grip now the car's going where he aimed, which was still 'too shallow' which was now a problem.
![]() Last edited by WolfWings; 04-28-2009 at 12:51 PM. Reason: Bah... I give up, live with the quote marks... |
#10 | |
I ♥ Yaris
Now I'm not an expert, nor do I claim to be, so I would like to know if/how I'm wrong. I'm not too proud to believe I'm always right, so please let me know if I am in error.
![]() ![]() ![]() ![]() ![]() Drives: 2008 Polar White LB Auto Join Date: Oct 2008
Would it be incorrect if I stated that when it rains or theres alot of water on the road, I FEEL it even that I have to drive slower around bends on the freeway and such because it FEELS like the rear is going to kick out, as compared to when not having the rear sway bar? I like the installation pics and description of the poster! |
#12 | |
What?
But, in reality, the back end is ACTUALLY more likely to kick out with the rear bar in place. That's an important thing to be aware of. It's one of the downsides of big swaybars. They increase confidence by reducing body roll and making the car FEEL better... but, at the limit, they often have effects that the driver doesn't realize... until it's too late. They make the car less forgiving to big driver errors. Find a safe place to push the limits of your car and learn what it's going to do! (even if your car is completely stock) |
#13 | |
Going Retro
Drives: '09 Tacoma | '90 Tercel Join Date: Aug 2010
That said, I want my ass to step out more, so looks like the 23mm will be the one for me. After almost getting blown off the road in a windstorm last friday on I-95 heading back up from Georgia, I can confidently mark down a sway bar as a 'safety feature'.
#14 |
Parallel Parking Pro
I guess expectations cause the placebo effect.
Leong's NCP91 Toyota Yaris E Hankook V12 Evo 195/55/15 on Buddy Club P1 replicas 15x7 ET +38 Stebel horns, Philips Silvervision turn indicator bulbs TTE Lowering Springs, Camber bolts TRD Blue brake pads Fujitsubo Super Wagolis axleback exhaust DC Sports header |
#15 |
^ A pretty good sized empty parking lot will do
#16 |
That is what I was reffering to Loren, that since Ive had my bar installed...it FEELS like the rear is more apt to kick out while going around bends on the freeway during wet and rainy weather. Almost like you can feel it getting to a threshold and you know you have to lay off the speed a little bit or it's gonna come on out on the bends, even though your not really flying or going all that fast down the expressway.
#17 | |
What?
#18 |
I'm used to winter driving, the ice and snow, etc so I've learned the best thing to not hit the brakes or anything else, just lay off the accelerator and let it coast down on it's own instead of trying to make it stop.
By the way, love that BRG car of yours! |
| DIY - rear sway bar [pics] | cali yaris | DIY / Maintenance / Service | 199 | 07-28-2022 05:25 AM |
| Rim Weights | bosbik | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 16 | 11-14-2009 06:42 PM |
| Possible Group Buy.. Racing Seats, Intakes? | TinyGiant | Items for Sale by private party | 60 | 09-11-2009 02:40 PM |
| Ultra Racing 23mm Rear Stabilizer Bar | Loren | Performance Modifications | 62 | 05-18-2009 07:20 PM |
| 12/20/08 Buddy Club USA 5th Anniversary Clearance SALE | DuckinOut | California | 3 | 12-18-2008 12:25 AM |
