Old 12-02-2008, 07:26 PM   #1
bdc87
HISTORY REPEATED 11/04/08
bdc87's Avatar
Drives: 07' MM Vitz LB
Send a message via AIM to bdc87
Exclamation Spew of Grease? Need Help.
While trying to get home today, I had to make a maneuver and the front drivers side tire went of the road into a small embankment, wasn't much I pulled out of it like going over a speed bump. I looked to make sure my wheel was ok and I saw a spew of grease all of the inner well, and back of the dust plate. I took the wheel off and cleaned everything up. Went for a small drive afterwords and everything sounds and looks ok, no more grease.
Where did this grease come from, what caused it, did I break something, and will the dealer fix it (my car is still under warranty)?
I plan to have it looked at but, wondering how serious it is.
bdc87 is offline   Reply With Quote
Old 12-02-2008, 07:40 PM   #2
Klink10
Klink10's Avatar
I think it might have come from the pins holding the caliper on. There is supposed to be some grease inside those little rubber boots along with the pins being lubed. Check that one of those didn't come unseated causing your problem. Check also because dirt and moisture can get in there causing the pins to freeze up down the road. All this does harm to the function of the brakes.....worth checking.
Old 12-02-2008, 07:55 PM   #3
FunctionSpec
Super Newbie
FunctionSpec's Avatar
Drives: 2007 Yaris Liftback White
Check the axle boot for any tears or punctures. Axle grease is pretty nasty stuff so if it was a light coat of grease and easy to clean off, then its something else.
FunctionSpec is offline   Reply With Quote
Old 12-02-2008, 08:09 PM   #4
bdc87
bdc87's Avatar
I checked the axle boot and didn't notice anything I might have to get underneath the car to look some more. It was pretty thick stuff and there was a good amount of it. It took about 6 papertowles to wipe it off the wheels.
I'm going to call the dealer tomorrow to make an appointment, should be under warranty right?
Old 12-02-2008, 08:50 PM   #5
Klink10
Klink10's Avatar
Should be....yes. Just don't tell them how it happened.
Old 12-02-2008, 09:03 PM   #6
FunctionSpec
Super Newbie
Turn the steering wheel all the way to the left and then right to check the front and back of the boot. Then roll the car forward a little and then follow the procedure again. Usually rips in the crease and you can't see it until you pull on the boot.
Probably isn't even from embankment and probably was there before but you just didn't notice it until you took your wheel off. How many miles are on your car?
Dealer should cover it under warranty but if looks like something poked and snagged the boot then its probably going to be a little tougher for them to cover it.
Old 12-02-2008, 09:17 PM   #7
bdc87
bdc87's Avatar
I know the grease came from the hit I don't know about the tear. I'm under the 36K miles. Called the service department today, I have a time for Thursday Morning. Guy said as long as it wasn't in an accedient or anything major it shouldn't be a problem.
My only question is what about my springs, and shocks voiding the warranty?
Old 12-03-2008, 12:59 PM   #8
IllusionX
Drives: 07 Yaris Sedan Aero
if it was the axle boot that was damaged. unless they prove your springs was the cause of the puncture. no it will not void the warranty.
Old 12-03-2008, 08:33 PM   #9
jambo101
jambo101's Avatar
Drives: yaris 08 sedan
The axle boot is the only place that has a significant amount of grease,if the boot wasnt torn i'd suspect the grease was already there and you ran over it.
Old 12-04-2008, 01:08 AM   #10
lilredrocket
Slowy getting there
lilredrocket's Avatar
Drives: 08 Liftback
some sealed ball joints can leak some to I have seen a good ammount come out of them
Old 12-04-2008, 02:22 AM   #11
bdc87
bdc87's Avatar
I'll let you guys no once I hear back from the techs.
Old 12-04-2008, 12:21 PM   #12
Shroomster
'07 to '12:2 wipers to 1?
Shroomster's Avatar
what color grease? and are you sure it wasn't 'mud grease' as in when you went off the road you could've hit a patch of greasy road mud and flung it everywhere?
Old 12-04-2008, 04:12 PM   #13
bdc87
bdc87's Avatar
Axle boot was torn. Mechanic said it couldn't be covered because the axle was flat instead of at an angle? This was only on the left side and not the right. $300 to fix. Your thoughts?
Old 12-04-2008, 04:44 PM   #14
FunctionSpec
Super Newbie
They are full of sh!t. Doesn't even make sense. They are looking for an excuse and blaming it on the lowered ride height of the springs.
Tell them to explain to you how a "flat axle" would cause the boot to tear. An axle at an angle would put continuous pressure on the boot causing it to eventually tear when it wears out.
Old 12-04-2008, 04:47 PM   #15
ztrack157
Vroom Vroom Beep Beep
ztrack157's Avatar
Drives: Powered Roller Skate
Send a message via AIM to ztrack157 Send a message via MSN to ztrack157 Send a message via Yahoo to ztrack157
I have the same problem. Noticeably never happened until I put my Tokico Shocks on. Went to take off my underpanel today and noticed the melted chocolate grease all over the place.
ztrack157 is offline   Reply With Quote
Old 12-04-2008, 04:49 PM   #16
ztrack157
ztrack157's Avatar
If theres a problem with the ride height then I'm getting new bump stops ad putting my stock springs back on.
Old 12-04-2008, 04:49 PM   #17
ztrack157
ztrack157's Avatar
Also I did not notice any tears in my boot as well.
Old 12-04-2008, 06:17 PM   #18
bdc87
bdc87's Avatar
Is something up with these Tokicos?
And for Function, I know the first thing they blamed it on was the springs, but how they were installed and not the height. How would a flat axle not cause this and how, and what do I say to them about it?
grease fittings on the 07 yaris 2 door yaris9876 DIY / Maintenance / Service 2 07-28-2007 08:37 PM
Best Grease to use on the belt? hasher22 DIY / Maintenance / Service 11 04-23-2007 03:20 AM
