Old 04-22-2007, 08:54 AM   #1
hasher22
Look mum no stars!!
hasher22's Avatar
Drives: Toyota Yaris 06
Best Grease to use on the belt?
Ok well after tryin so many times trying to get the 14mm bolt off the pulley, the belt is now makin a very loud squeakin noise.
The loud screeching sound is from the belt. The noise only screeches when i start the car, and the noise only goes for about 1 - 4 seconds then it goes away. And this scares the fook outa me....
What is the best grease / oil / lube to use on the belt to prevent it from makin that awful screeching noise when i turn on the engine.
Old 04-22-2007, 09:06 AM   #2
brickhardmeat
Lonesome Cowboy
brickhardmeat's Avatar
Drives: 2007 WHITE HATCHBACK
so is this a tension issue or do you need the lubrication? I know there are sprays out there but don't know what is best. I guess I am kinding of raising another question rather than answering yours.
SPONSORED BY
Old 04-22-2007, 10:53 AM   #3
acrbill
Drives: Polar White Hatch
Don't grease anything man! The reason its squealing is because its slipping a bit.
There is a spray you can use, it sets up tacky to help keep the belt from slipping. But your best bet is to just buy a new belt and make sure you have proper tension on itt.
Old 04-22-2007, 11:33 AM   #4
punch
punch's Avatar
1122 usefull posts, and now you want to grease a belt????
what does grease do? make things slippy, yeah it won't squeal, it won't do anything, the pulleys will spin, and the belt won't go ahead try it...
Old 04-22-2007, 12:10 PM   #5
YamilR
YamilR's Avatar
Drives: Absolutely Red Liftback
Send a message via Yahoo to YamilR
A little adjustment is all you need
YamilR is offline   Reply With Quote
Old 04-22-2007, 01:13 PM   #6
07typeS
07typeS's Avatar
Drives: 2007 White Toyota Yaris Type S
Send a message via AIM to 07typeS
yea that 14mm is a pain in the ass. What I found did the trick was put on a pair of gloves, grab a 14mm closed end wrench and just pull up. It works better if you make multiple hard pulls cause you will have a better chance to break it free.
TRD Springs w/ KYB Struts and Shocks, Custom CAI w/ K&N filter and pre filter wrap, Weapon R Header, Stock 15 inch alloys, Dezod Performance pads, Tanabe Front Strut Bar, 35% front door Tint and 20% Rear doors back Tint, De-Badged Ass, Custom painted flat black interior, Pioneer deh-p6700bt w/ IPOD hookup, Infinity components up front with custom mounted tweeter, Inifinity 6x9's out back, 1 12" kicker comp cvr........
07typeS is offline   Reply With Quote
Old 04-22-2007, 01:41 PM   #7
PetersRedYaris
PetersRedYaris's Avatar
Drives: 2005 Scion xB
Increase the tension if it's slipping but DO NOT grease the belt. If increasing the tension (don't over tension it) doesn't work, get some belt dressing. That stuff will increase the tackiness of the belt and eliminate the slipping. Overall, a new car with a new belt, proper tension is prabablty your only problem.
Old 04-22-2007, 08:39 PM   #8
hasher22
Look mum no stars!!
hasher22's Avatar
Thanks guys, the tension was put back to its normal state when i was tryin to get the pulley off.....after that the damn screechin occured. I guess i have to buy that Belt Dressing.....i sure hope that will work.
Old 04-22-2007, 10:23 PM   #9
PetersRedYaris
Use it sparingly, a little bit goes a long way.
Old 04-22-2007, 10:25 PM   #10
d4w1
Drives: Yaris Hatchback
Replace that worn belt.
d4w1 is offline   Reply With Quote
Old 04-22-2007, 11:23 PM   #11
whoguy
Drives: Yaris YRS Sedan
DO NOT GREASE THE BELT!!!!
Replace as per d4w1 and tighten to spec.
whoguy is offline   Reply With Quote
Old 04-23-2007, 02:20 AM   #12
hasher22
Look mum no stars!!
hasher22's Avatar
its not worn out, it doesnt need a replacement..........and i get it when you guys said "do not grease it"......as i said in my 1st post
"What is the best grease / oil / lube" to use, as i didnt know what kind of product to eliminate the screeching
Edit : The belt dressing worked like a charm......thanks petersredyaris! :)
DIY: Nonstop Tuning CR-Lite Pulley ChinoCharles DIY / Maintenance / Service 121 02-03-2010 05:41 AM
Seat belt reminder warning Beep Jord DIY / Maintenance / Service 28 04-09-2009 08:37 AM
ZPI pulley installed! PetersRedYaris DIY / Maintenance / Service 5 04-10-2007 07:31 PM
Belt Kitt DIY / Maintenance / Service 3 12-06-2006 11:37 PM
