Old 05-02-2009, 09:57 PM   #1
ezhacker1
ezhacker1's Avatar
Drives: Decepticon - Ravage
How to install RS spoiler?
Iv searched and searched and iv only found the sedan spoiler, and the lip spoiler DIYs. But i dont understand how to put on this RS one. Is there a write up? I guess i could go 3m tape and not have to drill, but i rather have it truly secured plus tape if i want.
Old 05-02-2009, 10:41 PM   #2
yarisugi
やりすぎだ~
yarisugi's Avatar
Drives: Me: Nuts:
I think ryank has one on his. Hope he sees this thread. I think he 3M taped it AND drilled in two screws where the holes were.
Old 05-02-2009, 11:12 PM   #3
YAR1S
YAR1S's Avatar
yeah I saw his spoiler. He sorta drilled into his hatch to fit it on there.....
I'd be sooo nervous doing that! I'd have to get it professionaly done.
ryank also said he had a bit of problem with leaking?
I cant answer completely for him but he'd be the guy to ask.
-Jen <3
Old 05-02-2009, 11:21 PM   #4
severous01
it's easy. get a piece of paper or plastic or whatever you can. cut it to match the spoiler, holes and all...tape it to the car and center it, line it up, level it whatever u wanna call it. then u drill the holes, clean up the metal, put some primer on the holes so they dont rust. then install the spoiler using supplied hardware.
that's what the dealer does....but they have stickers with markers on them to line it up properly, then drill holes through the holes provided in the 'installation kit' provided by toyota.
Old 05-02-2009, 11:36 PM   #5
yarisugi
やりすぎだ~
yarisugi's Avatar
Drives: Me: Nuts:
The hardware I got with the spoiler didn't make sense. I assume I'd have to buy self-tapping screws and drill from the top?
Old 05-02-2009, 11:46 PM   #6
1NZYaris1
1NZYaris1's Avatar
Drives: Yaris
here you go , this is the Toyota PDF
Old 05-03-2009, 12:32 AM   #7
ruimond
Drives: Yaris YR
I had my RS Spoiler installed professionally. But i did not want them to drill it on, so they said they would glue it on. Pretty sure they used something called "Sikaflex" or another type of bodykit glue to stick it on. Its like a black coloured glue.
The glue is very strong though, so will be hard to remove later.
Old 05-03-2009, 12:43 AM   #8
yarisugi
やりすぎだ~
yarisugi's Avatar
Drives: Me: Nuts:
Thanks 1NZYaris1, but unfortunately the one that ezhacker1 and I bought was not the OEM Toyota brand.
I notice the fasteners on the PDF - I'll see if I can find something like that at the local hardware store.
Old 05-03-2009, 01:04 AM   #9
ezhacker1
ezhacker1's Avatar
if the 2 screws were longer i could see how it would work. maybe im just not as intuitive.
Old 05-03-2009, 01:44 AM   #10
yarisugi
やりすぎだ~
yarisugi's Avatar
Drives: Me: Nuts:
I think it's kind of like this, but since you bought yours from kargoboy like I did, I think you'll probably have to find better fasteners at your local hardware store. The ones that came with the spoiler looked kind of funny to me. Don't mind the bad illustration -drawing with a mouse is a b*.
Old 05-03-2009, 01:52 AM   #11
ezhacker1
ezhacker1's Avatar
it seems that the end piece to the bolt, would go inside of the car, and fasten that way. but the bolt just doesnt seem long enough, ill look at it again.
Old 05-03-2009, 02:15 AM   #12
MadMax
MadMax's Avatar
Those are called nutserts and are used all over Jeeps, so they should hold the spoiler on just fine...
Cheers! M2
Old 05-03-2009, 02:35 AM   #13
1NZYaris1
1NZYaris1's Avatar
Drives: Yaris
Mines just glued on , been on for a year know no issues at all.
Old 05-03-2009, 06:27 AM   #14
yarisugi
やりすぎだ~
yarisugi's Avatar
Drives: Me: Nuts:
You will soon realize that you can't get to the inside of the car liftback roof to fasten from the inside unless you go through two planes with a super long bolt.
Those are called nutserts.
Thanks! I didn't even know there was a name for them.
Old 05-03-2009, 04:31 PM   #15
gwasabi
Drives: 07 Blazing Blue LB
Is the RS spoiler the large spoiler on the Sparks site?
Most Satisfying Crew
Serious Business...
MunkyWurks Garage - 8088488794
gwasabi is offline   Reply With Quote
Old 05-03-2009, 06:29 PM   #16
ezhacker1
ezhacker1's Avatar
yeah i was looking at it, and thinking...hmmm the two holes would have to be straight or it would suck.
and the name "nutsert" is hilarious to me.
Old 12-23-2009, 09:49 PM   #17
metalshark
MetalShark
Drives: 2008 Yaris LB
In my wild youth I used to install side mirrors on new Ford trucks at the dealer. The part Ford supplied was referred to as a riv-nut. One drilled a hole. Slipped in the nut. Then used a star washer, nut and bolt and set the riv-nut buy thightening the bolt with an air rachet while holding the nut,star-washer, and riv-nut stationary with a end wrench. The riv-nut would mushroom inside the panel like a pop-rivet and provide permanent steel threads in the panel to hold on the side rear view mirrors. One didn't need access to the inside of the door to use them. I installed thousands faster than flat rate.
Absolutely red, Drawtite hitch, CAI, Insulated Header, Amsoil 5w-30, Mag-drain plug, Red-Line MT-90 tranny oil, Scotch-Guard, Window Tint, Dash rug, Custom short throw shifter, Lowered OEM arm rest, Super-Turbo muffler/w chrome slash cut tip., TRD rear sway bar, sticky pads, front shock tower bar, RS grill badge, VVT-i emblems, Second tire set from Tirerack.com, DISABLED DAY TIME RUNNING LIGHTS, platform- style locking custom bike rack. 86K miles so far. 5 years use now on ceramic wrapped insulated stainless-steel header.
metalshark is offline   Reply With Quote
Old 12-24-2009, 12:50 AM   #18
yarisugi
やりすぎだ~
yarisugi's Avatar
Drives: Me: Nuts:
riv-nut! Thanks for the info.
I think the tool to drive that riv-nut is mega bucks.
DIY Sedan Spoiler Install Kaotic Lazagna DIY / Maintenance / Service 36 01-20-2020 12:35 AM
Compilation of Yaris How-tos/DIYs YarisBueller DIY / Maintenance / Service 39 04-28-2018 09:47 AM
Yaris RS + Rally Style Spoiler .. possible? bigsky2 General Yaris / Vitz Discussion 41 03-07-2014 11:09 PM
RS SPOILER ... SAD aznbabiegrlx0x0 Cosmetic Modifications (Exterior/Interior) 42 09-28-2007 10:49 PM
DIY Sedan Spoiler Install Interest? Kaotic Lazagna DIY / Maintenance / Service 28 09-12-2007 12:02 AM
