Old 09-16-2011, 03:08 PM   #1
ras3448
ras3448's Avatar
Drives: 2007 Red Sedan
Cup holder busted
I have a 2007 Sedan.
The driver side cup holder received an impact from a heavy object, and now the fluid opening mechanism is nonfunctional.
I can't seem to find a way to take it apart to assess the damage.
Has anyone taken apart a Yaris cup holder, or had similar symptoms?
ras3448 is offline   Reply With Quote
Old 09-16-2011, 07:20 PM   #2
Black_griffin6
Black_griffin6's Avatar
Drives: 09 Meteoric Metallic 3 door HB
Can you take any pictures of it?
Black_griffin6 is offline   Reply With Quote
Old 09-16-2011, 08:20 PM   #3
nemelek
DWEED
nemelek's Avatar
This might work till you find a fix.
Old 09-16-2011, 08:29 PM   #4
Revsson
Did you look at the pdf for the Instrument Panel?
Check out page 42, which shows how to take out the cup holder.
http://www.etimago.com/yaris/repairm...nt%20Panel.pdf
Otherwise, from page 40, it appears that you would have to take out the
whole Instrument Panel, and remove 3 screws from behind?
Let us know how you solve this issue.
Old 09-19-2011, 09:50 AM   #5
jambo101
jambo101's Avatar
Drives: yaris 08 sedan
I hate those cup holders, they usually spill fluid over your knee or soak anything you have in the small compartment under the cup holder and then with the mechanical operation it sooner or later fails,like my passenger side drink holder, refuses to lock in the closed position probably a piece of plastic worn out.I wish they had just put a recessed cup holder without the door mechanism,would have lasted the life of the car with never a problem..
Have Yaris will travel..
Old 09-21-2011, 07:01 AM   #6
MUSKOKA800
MUSKOKA800's Avatar
Squeeze the sides together to disengage the hinge pins. Watch for the small spring to eject.
Honestly, I don't recall anything as sexy as a "fluid opening mechanism" being included in the re-assembly after mine popped apart once due to a side impact.
cabin, cup holder, interior
CUP HOLDER REMOVAL? SweetRS Cosmetic Modifications (Exterior/Interior) 13 09-19-2016 08:43 AM
Dash Cup Holder dzcab Cosmetic Modifications (Exterior/Interior) 5 08-17-2011 10:24 PM
cup holder removal DOMAV General Yaris / Vitz Discussion 9 08-27-2009 11:32 AM
Install Oil Pressure, Voltage and Temperature Gauges with DIY Holder bieniman DIY / Maintenance / Service 4 05-19-2009 11:40 PM
A eye for a eye but a Ipod for a cup holder? yrsdrgn DIY / Maintenance / Service 30 05-08-2007 02:51 AM
