![]() ![]() ![]() Drives: 2007 Yaris Hatchback Join Date: Jan 2010
gears grinding
A few times I was sitting at a Red light and when it turned Green I pushed clutch real fast and put in 1st gear but it grinds the gears if I do it really fast. I didn't notice this before. If I push clutch and give it a second before putting in gear it wont grind. Is the synchronizers wearing out? I change fluid about every 30k with synthetic blend from walmart. I got 121k miles on car.
#2 | |
advocatus diaboli
i get the same thing, although I notice it more often since I changed to royal purple gear oil. I'm also getting a grind when I go from 2nd to 3rd quickly if I don't double clutch.
Your mom goes to college
Drives: 08 Vitz Join Date: Oct 2008
^^ Yep same here !!! Switched to royal purple a few months ago and have very notchy engagement and a desent grind when going 3-2 . I think its just to slick for the yaris gears imo .I will be switching to redline mt-90 next weekend and hope that helps...
Local Sh*t Disturber
Drives: 2009 Yaris LB Join Date: Aug 2009
I got the same problem fron 3rd-2nd..... Does it quite often!
You think your Yaris is low and fitted LOLzzzzz |
![]() ![]() Drives: 2008 toyota yaris Join Date: Mar 2011
Yeah, i switched to royal puckal at 55,000 and hate it.....I got MT 90 on the shelf for the 70,000 mile oil change coming up....I just shift nice and soft/smooth for now.....I got 65,000 on the car and mine doesn't grind into gears.
08 toyota yaris with some big tires lol 02 chevy duramax that runs 11.63 at 116 mph in the 1/4 mile
hmm, I have had the same kind of oil in for 2 years so cant say that is why. Guess I cant try to pop it into gear so fast.
only time I ever had an issue with grinding a gear when shifting is when I didnt push the clutch far enough and i was shifting faster then usuall. My hands were moving faster then my feet were. but under normal driving I never had a problem with this. I did notice you guys are running Higher milage then me and you guys gots 07-08s.. maybe '10 got some improvements or its just not worn in yet
Starting to happen more frequently think 1st syncro is getting bad. Better change oil to see how it looks
Feel like I am driving a dump truck again
| Grinding noise in reverse | NickNickNick | DIY / Maintenance / Service | 14 | 03-15-2013 03:10 AM |
| Grinding noise when switchingfrom second to third gear | Stiv | DIY / Maintenance / Service | 2 | 01-04-2011 04:35 PM |
| yaris 2009 MMT-problem in shifting gears. | matanfr | DIY / Maintenance / Service | 8 | 06-30-2010 01:37 AM |
| Stiff gears after a while | juxtapozed | General Yaris / Vitz Discussion | 10 | 05-05-2010 04:37 PM |
| 2004 yaris hatch, 2nz-fe, DFCO in all gears? | toyo | Fuel Economy Forum | 11 | 06-26-2009 02:21 PM |
