Old 04-28-2010, 05:49 PM   #1
juxtapozed
Drives: Yaris 1.3
Stiff gears after a while
Hello all,
New to the forums and apologies if this has been asked (couldn't find a topic through search).
At the start of the day, my car is fine to drive but the longer it's driven the more difficult it gets to change gears - especially into 2nd and 3rd. Everything else seems fine.
I've found that if it's revved higher than normal (3-4000rpm) for local driving that the gears get progressively worse quicker.
Hope someone can help as I can imagine the Toyota dealers not sorting something like this out cheaply!!!
Thanks in advance...
juxtapozed is offline   Reply With Quote
Old 04-28-2010, 06:30 PM   #2
Betrivent
Not quite a noob
Betrivent's Avatar
Drives: e46 325
Totally noob guess but maybe the transmission fluid needs changing?
Old 04-28-2010, 06:59 PM   #3
darkmoon87
darkmoon87's Avatar
Drives: 08 Yaris
well how long you had the car for? maybe needs a manual tranny fluid flush.
RIP Yaris, I will miss your superb handling a lot.
darkmoon87's picture thread
http://www.yarisworld.com/forums/showthread.php?t=10013
darkmoon87 is offline   Reply With Quote
Old 04-28-2010, 08:01 PM   #4
tomato
tomato's Avatar
how many miles do you have on the car?
Old 04-28-2010, 08:06 PM   #5
talnlnky
Audio Junky
talnlnky's Avatar
Drives: 08 liftback
sounds like a heat issue almost... fluid old... or maybe a leak has led to a lack of fluid.
Old 04-29-2010, 04:08 AM   #6
juxtapozed
Drives: Yaris 1.3
Had the car for just over 2 years, bought It on 57k, it's now done just over 64k.
The general consensus seems to be that it's the transmission fluid - I'll get this checked/changed/refilled as appropriate.
Probably a completely silly question, but is this a big/expensive job?
Thanks again
Old 04-29-2010, 06:16 AM   #7
darkmoon87
darkmoon87's Avatar
Drives: 08 Yaris
Thanks again
it can be easily done by yourself if you have a garage.
if you decide to do it at shops, it should cost you around 40~50 i think..
i got my manual tranny fluid done when it had 40k kms, (pretty early flush if you'd tell me) but holy shit, the shifting got so much noticibly better.
Old 04-29-2010, 09:49 AM   #8
juxtapozed
Drives: Yaris 1.3
Thanks for the info.
Forgot to mention this earlier, but I had a new clutch fitted about 18 months ago. Would this have any bearing on the problem as in transmission fluid is usually changed at the same time (I think)?
Old 04-30-2010, 07:40 AM   #9
mrb3990
Drives: 2010 Yaris Blcksandpearl sdn
Yes, the gear oil is usually changed when a clutch is replaced. I there any type of warranty on the clutch work? Maybe you can bring the car back to the same ppl?
mrb3990 is offline   Reply With Quote
Old 04-30-2010, 10:32 AM   #10
Zaphod
Drives: Big Yellow
They may have just put in a cruddy gear oil. I would check for leaks.
I put Redline in my TJ and it really made a difference, especially in the winter. It's not too hard to do and relatively inexpensive, on the Jeep the cross member/skid plate got in the way, but I imagine it's much easier on the Yaris.
Zaphod is offline   Reply With Quote
Old 05-05-2010, 04:37 PM   #11
BLOODY_STONE
Drives: 2009 toyota yaris 1.3 sedan
make sure u press the clutch to its end >>> its one of the yaris's disadvantages ... it happens sometimes ... just make sure u press the clutch as far as u can
BLOODY_STONE is offline   Reply With Quote
2004 yaris hatch, 2nz-fe, DFCO in all gears? toyo Fuel Economy Forum 11 06-26-2009 02:21 PM
Am I correct that the Yaris has an inredibly stiff chassis? regal Wheels, Tires and Suspension Forum sponsored by The Tire Rack 11 04-12-2009 02:50 PM
Optimal RPM for shifting Gears ? JapRulezz Performance Modifications 8 03-07-2009 04:16 AM
Transmission versus Gears caveatipse General Yaris / Vitz Discussion 3 09-23-2007 03:50 PM
Engine Run-on changing 1st/2nd Gears Ferret_san General Yaris / Vitz Discussion 4 09-06-2007 12:21 AM
