Old 10-09-2011, 08:48 PM   #1
ttr125fan09
ttr125fan09's Avatar
Drives: yaris
Intake Manifold
What need to be modified on the XB manifold to fit on the yaris?
ttr125fan09 is offline   Reply With Quote
Old 10-10-2011, 08:51 AM   #2
replace the throttle body mounting flange (xb is 3 bolt, yaris is 4 bolt)
the angle of the intake/throttle body mount is different, so you'll want a short ram intake (vs stock or cai)
Old 10-12-2011, 12:41 AM   #3
bzinn 1
bzinn 1's Avatar
Drives: 2008 Yaris HB
I have actually seen one on an xA this summer.....nicely made piece,spendy....but nice.
from what I could see the plate just needs cleanly cut off with like a bandsaw or chop saw for metal....and any good shop that tig welds....think outside the box....motorcycle shops.....can make a new plate out of SS sheet and drill the new holes and tig it back on...it looks very doable.
Old 10-12-2011, 09:47 AM   #4
jekqmb
Local Sh*t Disturber
Drives: 2009 Yaris LB
What im doing for the custom intake mani from the NOS Yaris I bought is using a Matrix TB spacer and having it welded on, then just bolting the Yaris TB up. Its basically an adapter.
Old 10-12-2011, 11:05 AM   #5
sito
Drives: Toyota
Hi jekqmb. Any pics of your intake manifold?
Thanks...
sito is offline   Reply With Quote
Old 10-12-2011, 11:21 AM   #6
jekqmb
Here it is, I bought it from Jay. I will be posting pics once i get the TB spacer on it and send it off to get powdercoated.
Here it is on his car from last year!
Old 10-12-2011, 11:38 AM   #7
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
Any plans for a dyno session?
Old 10-12-2011, 11:58 AM   #8
jekqmb
Yes for sure!
Old 10-14-2011, 11:00 PM   #9
sito
Drives: Toyota
Thanks jekqmb.
Old 10-14-2011, 11:27 PM   #10
jekqmb
Got the manifold today! Looks really good, here is another pic, lemme know if you want any other angles of it! Im getting a Polished TB adapter welded on Monday then the Mani is getting painted Dark metallic Purple Tuesday, then its going on wedsnday.
Old 10-15-2011, 03:19 AM   #11
isnt that manifold really only good for a turbo application?
Old 10-15-2011, 03:54 PM   #12
jekqmb
Ya the XB one from weapon r is i heard, there is a guy here in st.louis using one na on his XB and only gained like 2whp.
Ill keep you guys updated on the one i got, i will be using it with nitrous. I wrote a review on Microcarmag.com about it, so follow along!
http://www.microcarmag.com/product-s...nifold-review/
Old 10-15-2011, 05:24 PM   #13
CrankyOldMan
Could you do me a huge favor and measure the openings and their spacing? I've got a corolla intake manifold that I'm going to modify for a 1.8L throttle body (like in this thread). The corolla openings are 35 x 52 mm and they are 87.5 mm apart.
Old 10-15-2011, 06:21 PM   #14
jekqmb
Sure will do! Im actually working on it right now sanding the old poopie paint off to prep for powdercoating!
Old 10-15-2011, 06:43 PM   #15
CrankyOldMan
Thanks! I did a bit more searching and found that the cylinders are 75mm dia. and 8mm apart, so the spacing should be 83mm. Just need the opening dimensions and the bolt locations and I can get a CAD model rolling.
Old 10-15-2011, 09:11 PM   #16
The short runner design may produce some high-end power, but the torque will probably suffer.
The Weapon R one has longer runners but a poor plenum design.
Yes for sure!
Do you have a before dyno?
Old 10-15-2011, 10:07 PM   #17
jekqmb
Yea i do i need to find the sheet, i have to go digging for it! haha
Old 10-15-2011, 10:16 PM   #18
jekqmb
So you need the inlet size and the bolt locations?
Custom Intake Manifold + Direct Port Nitrous blacksandiegovitz Performance Modifications 9 04-21-2010 08:05 PM
Yaris Intake Manifold richardholdener Performance Modifications 201 05-18-2009 12:58 PM
Intake Manifold Gasket? Nexus1155 DIY / Maintenance / Service 6 11-18-2008 09:03 PM
Official Richard Holdener *MID-RANGE* Intake Manifold List WolfWings Performance Modifications 59 11-14-2008 12:26 AM
Intake Systems Decision Maker.. Blenjar Performance Modifications 25 09-15-2007 11:07 PM
