Old 10-22-2008, 10:01 AM   #1
Nexus1155
Bathroom + Laptop = <3
Drives: Audi
Intake Manifold Gasket?
Hey, I didn't know where to ask this, I know that the intake manifold is a plastic pos, but i was wondering if it had a gasket to it so i can get a copy of the intake manifold flange easier.. Thanks! and if anyone knows how much it would be?
Old 10-22-2008, 11:10 AM   #2
ChinoCharles
Drives: LB
Why don't you just call a Toyo parts department? Or Rockland?
Old 10-22-2008, 11:56 AM   #3
jkuchta
Drives: 2007 Yaris hatch (red)
The gasket is made from a rubber o-ring material, and is not flush with the port walls, so you can't use one of these gaskets to port match like you would with, say, a chevy or ford V-8 intake gasket.
The oring gasket actually sits in its own channel away from any of the port walls.
jkuchta is offline   Reply With Quote
Old 10-22-2008, 12:54 PM   #4
Nexus1155
Drives: Audi
i just wanted to trace one onto metal so i can make a flange :-/ anddd i was in school and lazy but im out eating mac & cheese and ill see if i can make some time...
Old 10-26-2008, 04:41 PM   #5
Tamago
Tamago's Avatar
Drives: UZJ100
i have an intake manifold if someone wants to buy it.. from an 04 xA (so different throttle body) but could be used for prototyping
by the way your "crappy plastic intake manifold" actually makes more sense than an aluminum one... heat soak is not your friend.
Old 10-26-2008, 06:42 PM   #6
PetersRedYaris
PetersRedYaris's Avatar
Drives: 2005 Scion xB
Actually, this is the one reason plastic manifolds makes sense. No more crappy gaskets... They have an O-ring for each intake port and the throttle body and don't need to be replaced every time they are disassembled. It makes it super simple and fast to remove and re-install your intake. Yeah for plastic car parts...
The downfall, in a front end collision they crack easily if the radiator is pushed into them. Perhaps this is better than a chance of engine block damage though.
Old 11-18-2008, 08:03 PM   #7
bobobitch
bobobitch's Avatar
Drives: Yaris HB
Send a message via AIM to bobobitch Send a message via MSN to bobobitch Send a message via Yahoo to bobobitch
weapon R is coming out with an aluminum intake manifold pretty soon so instead of replacing your old one with oem i would just wait it out until the weapon R one comes out
bobobitch is offline   Reply With Quote
EBay: Yaris Intake Manifold ChinoCharles Performance Modifications 21 10-22-2008 04:35 PM
turbo intake manifold turboyaris Forced Induction Forum 17 07-06-2007 08:59 PM
Thinking about making a full Intake Manifold Replacement YogiYaris Performance Modifications 26 06-07-2007 10:26 PM
