Old 11-27-2011, 11:19 PM   #1
CanIHazYarisHatch?
Drives: 2012 Yaris 3-door w/5-speed!
A question about wheel weight...
I am getting a '12 Yaris in a couple of months with pressed steelies (L 3-door hatch), and I just want confirmation from anyone who might know:
http://www.toyota-parts.com/scripts/...idproduct=-312
Do these machined aluminum wheels weigh more than the stock steelies? If so, by how much?
Does anyone have some solid numbers on these wheels? Thanks.
CanIHazYarisHatch? is offline   Reply With Quote
Old 11-28-2011, 12:42 PM   #2
CanIHazYarisHatch?
Does no one know the weight of these wheels? I really am surprised!
Old 11-28-2011, 12:53 PM   #3
I have no concrete answer for you but since steelies weigh approx 1 lb/inch + 1 lb, I'm guessing those alloys will be up to 2 lbs heavier.
Old 11-28-2011, 02:37 PM   #4
A-Dingo-Ate-My-Baby
Drives: yaris
guess ?
they are the same or slightly heavier.
standard mom+pop sedan OEM alloys are usually the chunkiest and strongest of all alloy wheels...hence a tad heavy.
for less dollars (100 each) you can get a lighter aftermarket 15 inch alloy somewhere
A-Dingo-Ate-My-Baby is offline   Reply With Quote
Old 11-28-2011, 03:16 PM   #5
CanIHazYarisHatch?
Thank you very much.
Originally Posted by A-Dingo-Ate-My-Baby View Post
guess ?
Thank you also, very much. Problem is, I haven't seen one yet on YW that I like. Trust me, I went through the "wheels on your car" thread. None of them appeal to me, unfortunately.
I just like this set because they aren't overly "blingly", giant heavy wheels that will hurt my MPG for looks.
For me, polished aluminum > chrome-plated anything any day.
Again, thank you both. I think the trade-off is worth the slightly higher weight. Plus, the price is sweet enough for me to justify.
Old 11-28-2011, 04:10 PM   #6
A-Dingo-Ate-My-Baby
Drives: yaris
these are under 100 bucks each and are about as non-flashy as you can get, they look so much like an OEM
http://www.tirerack.com/wheels/Wheel...Silver+Painted
I use them as winter wheels http://www.yarisworld.com/forums/showthread.php?t=37010
these here are ten spokes and on sale for 84 bucks
http://www.tirerack.com/wheels/Wheel...All&sort=Brand
Old 11-28-2011, 04:15 PM   #7
CanIHazYarisHatch?
Um, the Yaris has four lugs, not five.
Old 11-28-2011, 04:35 PM   #8
A-Dingo-Ate-My-Baby
Drives: yaris
Um, all those wheels I showed you have a 4x100 lug version
in fact this is how most wheels are photographed on wheel buying web
sites, the 5 lug money-shot.
When you actually put in your vehicle data then you find out if they
have a 4x100 version of a rim in a particular size and width
They only took a picture of the 5 lug.
Old 11-28-2011, 05:03 PM   #9
Black_griffin6
Black_griffin6's Avatar
Drives: 09 Meteoric Metallic 3 door HB
These are the wheels I have: http://farm7.static.flickr.com/6177/...fb82c0a292.jpg
They are SSR Type F's in silver, and mine are 16 inches, they weigh 11lbs each which is lighter then the 15inch OEM steelies.
Mine are also the 10 spoke version, I believe the ones in the picture are 12.
Edit: And yes, mine also are the correct bolt pattern.
Black_griffin6 is offline   Reply With Quote
Old 11-28-2011, 11:54 PM   #10
mr9865
$10.25/hr frying chicken
mr9865's Avatar
Drives: 2012 Yaris L
I almost bought theses wheels. I called him up and they are OEM
http://www.ebay.com/itm/SET-4-ALLOY-...item336dca48b2
mr9865 is offline   Reply With Quote
Old 11-29-2011, 02:36 AM   #11
CanIHazYarisHatch?
Oh, my mistake. Thanks!
Old 11-29-2011, 02:42 AM   #12
CanIHazYarisHatch?
They look nice...
I love symmetrical wheels. I can't stand offset patterns that don't line up equally all around. But these look pretty sweet, if a bit plant-like.
Official YARIS Wheel & Tire Guide Black Yaris Wheels, Tires and Suspension Forum sponsored by The Tire Rack 403 08-09-2025 11:20 PM
new wheel? Nekofelin DIY / Maintenance / Service 1 08-10-2010 02:37 PM
Steering Wheel Issue. Twistoffate0817 General Yaris / Vitz Discussion 8 01-31-2009 07:38 PM
weight on rs 15 inch wheel. marcus Wheels, Tires and Suspension Forum sponsored by The Tire Rack 3 05-04-2007 11:20 AM
Wheel Care Question - Polish coming off? Ran Kizama Wheels, Tires and Suspension Forum sponsored by The Tire Rack 0 04-25-2007 05:49 PM
