Old 11-29-2011, 12:37 PM   #1
Black_griffin6
Black_griffin6's Avatar
Drives: 09 Meteoric Metallic 3 door HB
Trying to install sway bar
Hey guys, i've been trying to install my UR 23mm rear sway bar, but I can't get the bolt that connects to the shock loose, it seems like it's permanently glued on or something.
I've read all the DIY threads about it, and everyone boats about how it's so easy, yet this is the second day i've tried this. :frustration:
Anyone else had this problem?
Black_griffin6 is offline   Reply With Quote
Old 11-29-2011, 01:09 PM   #2
Mine were torqued pretty good, but they broke loose without issue using a 2' breaker bar.
Old 11-29-2011, 01:29 PM   #3
Black_griffin6
How did you get yours loose? I've read that some people heated up the bolt so it expands for it to become loose.
Old 11-29-2011, 01:36 PM   #4
No heat - Just leverage. It's amazing how adding some length to your socket works. I tried breaking them loose with just a 10" long ratchet and couldn't, so I grabbed my 2' breaker bar and put that on the socket and it came loose with little effort. A piece of pipe over the handle of the ratchet works equally well.
Old 11-29-2011, 01:42 PM   #5
Klink10
Klink10's Avatar
I'm answering in a PM to you.
Old 11-29-2011, 01:56 PM   #6
mazilla
advocatus diaboli
mazilla's Avatar
Drives: 07 Yaris hatch
I just stared them down them until they worked themselves loose...they were no match for my glower power. :)
Try hitting them with some-break,let it soak for an hour or so, then slide a 2' pipe over the ratchet handle and give it hell.
-Type 07 FFL-
My odometer 03/11
Old 11-29-2011, 05:15 PM   #7
Black_griffin6
I got it! Thanks!
Actually most of the trouble I had later on was actually getting it lined up with the holes, it's a really thick bar.
It's on now, so i'm hoping to test it out soon.
Old 11-29-2011, 07:23 PM   #8
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
I don't recommend using a cheater bar on your socket wrench. Too much chance of busting the internal ratchet mechanism. Harborfreight has breaker bars for less than $20. I bought an 18"-3/8" drive bar before trying to do my NST crank pulley and it worked great! I've also used it on pretty much every bolt of the transmission I tore down, as well as a gear puller main screw.
Hands down one of the best low cost investments you can make to your tool box. I'm tempted to buy a 24"-1/2" but the only bolts I couldn't loosen with the current bar were the three that were inside the bell housing. That was only an issue of them being too deep, causing the socket to roll off the bolt head. My air impact wrench came to the rescue, which is odd considering how poorly it works.
Old 11-29-2011, 08:51 PM   #9
That's why I now own the 2' 1/2" breaker bar. I shattered three 3/8" drive ratchets in one day trying to break some bolts loose on my Celica with a 3' piece of pipe on the ratchet.
Old 11-29-2011, 08:57 PM   #10
CrankyOldMan
Wow, that's just crazy! I haven't tried any body/frame bolts yet, so I just may get a 1/2" before I try any of those.
Old 11-30-2011, 12:43 AM   #11
Yes, that's a great tool to have around. Or longer.
Old 11-30-2011, 08:27 AM   #12
racerb
I use a 1/2" drive 2 1/2' breaker bar most of the time for stubborn nuts and bolts. But when all else fails, I keep one of these in all my vehicles for changing wheels, it works good as a breaker bar too!
http://www.brandsport.com/grla-1721.html
racerb
racerb
'86 Celica GT
'87 Celica GT-S
'98 Rav4L
'01 Tundra SR5
Old 11-30-2011, 12:31 PM   #13
marcus
toyota
marcus's Avatar
Drives: 2007 Yaris RS Blazed
got a 2 feet breaker bar/ pipe sitting on my trunk.. its a savior for me atleast.
Old 11-30-2011, 12:46 PM   #14
the 23mm sway bar is stiffer, so it is just a little more difficult to install. Having two people helps a lot to get it lined up with the shock bolts.
Old 11-30-2011, 12:49 PM   #15
marcus
toyota
marcus's Avatar
i agree i person was a bitch... 2nd person will help you stretch it out to go in..
Old 11-30-2011, 03:40 PM   #16
Black_griffin6
Yeah, I have the 23mm. It was a pain to get on but it's so worth it.
Old 11-30-2011, 01:13 PM   #17
^ actually it's pushing it in, not stretching it out (it goes on the inside of the shock), but whatever we all understand I think
TRD rear sway bar install sg11 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 3 08-18-2011 01:57 PM
My Ultra Racing rear sway bar install CtrlAltDefeat Wheels, Tires and Suspension Forum sponsored by The Tire Rack 49 03-03-2011 02:08 AM
front sway bar install birdman DIY / Maintenance / Service 5 10-04-2009 08:41 AM
TRD Rear Sway Bar Install ?? bikegerm Wheels, Tires and Suspension Forum sponsored by The Tire Rack 6 12-26-2008 01:46 AM
