Old 05-20-2011, 12:41 PM   #1
sg11
Drives: 2010 Liftback
TRD rear sway bar install
I've been reading on here for a while and noticed conflicting answers.Does if make a difference whether a rear sway bar is installed with the car jacked up versus on the ground?
sg11 is offline   Reply With Quote
Old 05-20-2011, 01:47 PM   #2
BEEF
BEEF's Avatar
Drives: 2008 yaris 3d
I would think that if the car is on jack stands, you could more easily adjust one side or the other to align the holes better if needed.
it really doesn't take that much more to put the car on jackstands. I would think just get the tires off the ground and the weight off the suspension.
I haven't put one on but that is just my assumption from what I have read and the way it looks like it goes on. I plan to put one on from microimage at some point. they have a 19mm one and a 23mm one. I think the TRD one is the equivalent to the 19mm one so you could save some green and get it from garm.
http://shop.microimageonline.com/Ult...R-AR19-100.htm (19mm one)
http://shop.microimageonline.com/Ult...R-AR23-100.htm (23mm one)
Old 05-20-2011, 02:22 PM   #3
SLIK4
Michael
SLIK4's Avatar
Drives: 07 Silver Yaris Sedan
i was going to install mine without jacks in my driveway but gave up pretty quickly. ended up grabing the jacks and taking off the rear wheels. def the way to to it.
SLIK4 is offline   Reply With Quote
Old 08-18-2011, 01:57 PM   #4
A-Dingo-Ate-My-Baby
Drives: yaris
no difference. taking the passenger side rear tire off makes it easier
to bolt up the bar (extra reach around the muffler) but you don't have to.
Or just climb under there and bolt it on, no jacking required.
A-Dingo-Ate-My-Baby is offline   Reply With Quote
front sway bar install birdman DIY / Maintenance / Service 5 10-04-2009 08:41 AM
TRD Springs Shocks and Sway Bars IN STOCK Sparks Toyota-TRD Sparks Toyota 0 03-12-2009 09:54 AM
wtb trd sway bar toupy Willing to Buy by private party 8 02-23-2009 06:00 PM
TRD sway bar and tire wear Cutie Pie #2 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 26 02-01-2009 08:07 AM
